Think I have a handle on carb problems
#1683129
10/07/14 06:30 PM
10/07/14 06:30 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
Just had a nice chat with Patrick@ pro systems. We used to work together years ago, was nice to see how he is doing. Anyhow this pro form 950 that was " stuck" on my little engine masters 318 I suspect wasn't the dynocarb I was told it was, and having sat around likely for years, it seems to be full of gremlins. Rather than buying a new carb, gonna have these folks go trough it stem to stern, set it in the ballpark for this engine, so I at least know the carb is fresh and in good working order. Probably should have done this before I ever raced the car..... Blowing out dirty needles, leaks, etc,etc Thought about buying a new carb, but it's a bunch cheaper to have this one refurbished, and calibrated to my combo
Re: Think I have a handle on carb problems
[Re: Thumperdart]
#1683131
10/07/14 08:14 PM
10/07/14 08:14 PM
B3422W5
Portage,michigan
Thanks, thump. He said they redo the emulsion circuits, will pretty much replace everything. I told him a few basics I know about how the carb is currently setup, he said it wasn't remotely close to where it needs to be. At least this way I will know it works correctly and have a known good working unit. Something I definately don't have now. Kinda makes me mad the guy I bought the motor from gave me this junk carb that in no way was used and properly tuned on an engine masters dyno. When I went back and read the article on this motor, I noted they used a Holley 950hp, this is a proform... So definately not the carb I was told it was. It is what it is I guess. Otherwise the little motor seems fine
[Re: B3422W5]
#1683132
10/07/14 08:36 PM
10/07/14 08:36 PM
Thumperdart
State of confusion
First, people need to keep it real and be straight up on parts or whatever it is. 2nd, tuneable circuits and lowered ifr`s make it WAY more tuneable and sensitive once it starts comin around. Good luck..........
[Re: B3422W5]
#1683134
10/08/14 09:56 AM
10/08/14 09:56 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I'm sure Patrick will have it working good when you get it back. He's done some great work for me.
