A-body rear end size
#1683100
10/07/14 05:35 PM
10/07/14 05:35 PM
Posts: 186 South Carolina
KRYPTONITE
South Carolina
I'm building a 72 scamp and wanting to know the length on the Rear end and wheel/tire combo. you guys have. I know the stock rear A-body is 52 1/2 long. I am going to run Cal tracs, and mini tub the car, want to run a 10inch wheel and fit 275 drag radial under it, but also have room to run a 28/10.5 slick. so post some rear lengths and tire size (or what you did to run this size tire combo.) Thanks
Re: A-body rear end size
[Re: KRYPTONITE]
#1683101
10/07/14 06:37 PM
10/07/14 06:37 PM
Posts: 1,490 smyrna,tn
draginmopars
smyrna,tn
70 Dart Custom mini tub Dana 60 53" flange to flange 10" wheel 5" back space 275 ET Pro
Ha-Ha Racin Havin Fun 101
Howard
68 "Cummins" Satellite 70 W-2 449 "More Door" Dart 70 340 Dart Swinger, 4spd 71 360 Dart Swinger 72 540/ 518 Dart Swinger 73 airwolf 446/a-500 Cuda 73 "Cummins" Crew cab-car hauler 84 446 Dodge Rampage (tube chassis) 92 CTD 11' flat bed 92 CTD club cab 07 Dodge Caliber
[Re: RobX4406]
#1683115
10/08/14 08:01 PM
10/08/14 08:01 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
mini tub and spring relocation with a 275/60 is a piece of cake.
The right way to go is car tubbed, get wheels and tires you plan to use and measure mount to mount... no mistakes!
Wheel backspace plays a HUGE part of the equation.
That's what I did on my 69 Dart and 325s.
[Re: RV2]
#1683117
10/08/14 09:12 PM
10/08/14 09:12 PM
Posts: 1,357 central Florida
VL21
central Florida
Keep in mind that the Valiant has a MUCH bigger wheel opening than a Dart. An 8" factory ramcharger wheel (4 1/4 or 4 1/2 BS) has pretty good clearance with everything stock, a little careful work and some backspace juggling might get you what you need.
It takes gasoline to interest me.
