RTV for use with gasoline??? #168304
12/15/08 11:06 PM
12/15/08 11:06 PM
Manitoba, Canada
DaytonaTurbo Offline OP
Manitoba, Canada
Any RTV work well against gasoline? Got a plastic fuel tank with a rubber gromet that a metal fuel line passes through, and it's leaking a little. I tried a new gromet, but no dice, still leaks a little. Any suggestions?
Re: RTV for use with gasoline??? [Re: DaytonaTurbo] #168305
12/15/08 11:14 PM
12/15/08 11:14 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
nope
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: RTV for use with gasoline??? [Re: DaytonaTurbo] #168306
12/15/08 11:21 PM
12/15/08 11:21 PM
Snowing in the north!
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
Try some Barge all purpose cement. Even recommended
for sealing gasoline tanks. Doesn't harden or crack
and gets stronger with age. I dont know exactly
where you buy it but I have 3 tubes. PM me if interested.
Re: RTV for use with gasoline??? [Re: Dart 340] #168307
12/15/08 11:30 PM
12/15/08 11:30 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Moroso epoxy?
Re: RTV for use with gasoline??? [Re: Neil] #168308
12/15/08 11:48 PM
12/15/08 11:48 PM
Andrewh Offline
Andrewh  Offline
ultra copper should
Re: RTV for use with gasoline??? [Re: Andrewh] #168309
12/16/08 01:36 AM
12/16/08 01:36 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have had good luck with the Mopar gray RTV. I used it on the fuel line fittings at the carb when I had no pipe dope and it sealed it up good. I have not touched it in 2 years and it has not leaked at all. Ron
Re: RTV for use with gasoline??? [Re: DaytonaTurbo] #168310
12/16/08 07:09 AM
12/16/08 07:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes there is, its made by Dow Corning RTV#30, I
used it in the fuel lab at Chrysler all the time,
its very pricey but works great if its not submerged
in fuel all the time
Re: RTV for use with gasoline??? [Re: MR_P_BODY] #168311
12/16/08 09:45 AM
12/16/08 09:45 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Get a tube of Seal All at the parts store. That will do it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: RTV for use with gasoline??? [Re: CJK440] #168312
12/16/08 10:00 AM
12/16/08 10:00 AM
Dart 340 Offline
moparts member
Dart 340  Offline
moparts member
If you have a plastic tank, it's PE
(polyethylene. There are a very few adhesives
actually formulated to bond it, and over time
the bond will degrade. I work with this stuff
every day, and an adhesive engineer. You will
find some things that will work short term, but
over time, all will fail. It's a makeup of the
resin. Many PE tanks have a spun welded fitting
on them. You might try using a clamp type fitting
and running the steel tube on both sides if you
really want a permanent seal. I did that with my
fuel cell and it worked pretty well.
Re: RTV for use with gasoline??? [Re: DaytonaTurbo] #168313
12/16/08 11:33 AM
12/16/08 11:33 AM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
Motoseal is pretty good.
