Cam install tool
#1682852
10/06/14 10:39 PM
10/06/14 10:39 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Anyone know of a cam install tool specific to big block mopars? I'd prefer not to buy a $150 tool that works on a all engines as I dont work on anything else but B engines. I suppose I could make one but dont have lathe access
Re: Cam install tool
[Re: NTOLERANCE]
#1682854
10/06/14 10:49 PM
10/06/14 10:49 PM
RapidRobert
Me too, no parts house here rents one. cam bearing installation (adjustable) tool. there's gotta be a good backyard solution
[Re: RapidRobert]
#1682855
10/06/14 10:51 PM
10/06/14 10:51 PM
NTOLERANCE
Madison Wi
SOOORRRY - I meant cam BEARING install tool.. Sheesh....what the heck was i typing....
[Re: NTOLERANCE]
#1682856
10/06/14 11:15 PM
10/06/14 11:15 PM
Posts: 4,945 WI
Dcuda69
WI
[Re: Dcuda69]
#1682857
10/07/14 12:35 AM
10/07/14 12:35 AM
RapidRobert
Dcuda is the man I'm gonna get one
[Re: NTOLERANCE]
#1682859
10/07/14 01:44 PM
10/07/14 01:44 PM
Posts: 4,799 ILL
MLR426
ILL
[Re: RapidRobert]
#1682860
10/07/14 10:38 PM
10/07/14 10:38 PM
Posts: 4,945 WI
Dcuda69
WI
lol...even a blind squirrel finds a nut once in a while!
[Re: moparx]
#1682865
10/07/14 11:48 PM
10/07/14 11:48 PM
Posts: 4,945 WI
Dcuda69
WI
$50.00 and you can rent it to your buddies because it will work on anything
http://www.amazon.com/Lisle-18000-Univer...stallation+tool
I even looked on amazon and somehow missed this. Thanks
looks like $125-134 to me instead of $50?
$50.00 when I posted it yesterday Sounds like some of these guys got them ordered..hopefully they'll get them
[Re: Dcuda69]
#1682866
10/08/14 01:19 AM
10/08/14 01:19 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Yep, there are limited quantities. When I ordered one it said 11 left. Once that special is gone, that's it.
[Re: NTOLERANCE]
#1682871
10/09/14 09:11 AM
10/09/14 09:11 AM
Challenger 1
Cincinnati, Ohio
I got one of those Lisle cam bearing tool in a E bay deal years ago with several other tools that I was after. I already had a snap on cam bearing driver from years earlier. The lisle tool looks almost exact to the snap on tool except it had rubber sleeves around the expanders and the snap on has multiple rubber o rings around it's expander. The snap on tool was a much better easier tool to use and after 25 years of use the o rings are still good and have never given me problems or wore out. I see Lisle provides extra rubber sleeve for each adapter and I know why, they wear out and are damaged pretty easy. I didn't like them because the seemed to swell up from oil use also. They are too easy to get slid out of place. I re sold the lisle tool. Not saying it's a bad tool but there is difference and the snap on tool is much nicer to use. And I'm not even sure it's a "snap on" tool, I just got it from the snap on guy a long time ago. I'll see if I can get a picture of the snap on expanders with the o rings.
