a customer's duster with a 520"
#168265
12/15/08 10:07 PM
12/15/08 10:07 PM
Posts: 2,119 sc
tjmarcus1
sc
here's the lowdown. he had someone build his motor, but he was pretty unhappy with it. so he brings it to me to "fix it". the last 2 passes it made before it arrived was a 6.66 & 6.69 at about 106mph, i think. when i took the motor out of the car i noticed it had 4 header gaskets on one side and 1 on the other. this was a sign of things to come. virtually nothing about the engine seemed to be correct: no thrust button, intake gaskets didn't fit, ALL those header gaskets hadn't been trimmed, dist. was untouched, the rings looked like a child had cut them as they had evidence of the ends butting,and so on........ i basically reused his parts along with a new set of rings. i managed to get what was supposed to be a "14/1" motor,{ but was actually about 12.4}, up to nearly 14/1 at this point. after all this he called me today to tell me it went a 6.20 at 116 something. that's footbraking with a glide and about 3240#. he was tickled.
Re: a customer's duster with a 520"
[Re: toddd]
#168267
12/15/08 10:32 PM
12/15/08 10:32 PM
Posts: 2,119 sc
tjmarcus1
sc
It must be a Chevy shop the specializes in roundy round motors...i had the same experience...except I had 15.2-1 comp NOT the 13.5 as they calculated.
Good for you for salvaging the motor.
Todd
it was indeed a chevy shop, which probably explains the glide leaving on the footbrake.
[Re: tjmarcus1]
#168270
12/15/08 11:10 PM
12/15/08 11:10 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i hate chevy shops. good job TJ. people around here wonder why i drive 900 miles for good machine work and i can only point at the chevy guys that are on their third engine for the season
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: slantzilla]
#168272
12/15/08 11:44 PM
12/15/08 11:44 PM
Posts: 3,142 Central NC
gch
Central NC
I saw a 509 BB Chevy blow it's guts out on the dyo on it's first pull at the race shop. Guy had just paid a ton to a supposed "Chevy Guru". AFter the smoke cleared it was plain to see the he had left the rod bolts loose. Customer hauled it back to him and the guy convinced him we were lying to him. Told the guy he was making too much horsepower for the rods.
Glad you were able to save your customer some pain.
That is freakin hilarious.You can't fix stupid!
[Re: Thumperdart]
#168274
12/15/08 11:53 PM
12/15/08 11:53 PM
Posts: 2,119 sc
tjmarcus1
sc
Good job tj, maybe you can fix my heap and get it to go 116 in the 1/8th......
i would love to try, dom. there isn't that much distance between us, is there?
Post deleted by Defbob
[Re: tjmarcus1]
#168276
12/16/08 12:05 AM
12/16/08 12:05 AM
[Re: tjmarcus1]
#168280
12/21/08 11:54 PM
12/21/08 11:54 PM
sixpackgut
Charleston
yep and only 688 at 6.20. 100 hp difference. thats a little funky.
[Re: sixpackgut]
#168281
12/22/08 10:42 AM
12/22/08 10:42 AM
Posts: 2,119 sc
tjmarcus1
sc
yeah, but that's a lot of weight to be leaving on the footbrake with a 2-speed. it c r a w l s off the line.
