Torsion bar crossmember #1682636
10/06/14 11:21 AM
10/06/14 11:21 AM
Chicago
rocksmopar Offline OP
Chicago
Hi everyone, I need some advice, I just found a bunch of rot on the torsion bar crossmember of my 73 Barracuda. Is that as easy as drilling out spot welds to remove and replace or is it more complicated? I'm not a body sheetmetal guy but am thinking of tackling this myself. Floor pans are in good shape. Any input?
Looking for affordable 72-74 Cuda parts
Re: Torsion bar crossmember [Re: rocksmopar] #1682637
10/08/14 11:22 PM
10/08/14 11:22 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
its not as easy as you are thinking...
the entire main floor pan has to be drilled out to be able to replace it in one piece.
Re: Torsion bar crossmember [Re: flypaper] #1682638
10/09/14 12:02 AM
10/09/14 12:02 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
It can be replaced without removing the floor.
Do have to drill the spots at the floor to the x-member.
Then the spots for the x-member to the front frame rails.
Then the spots for the x-member to the rockers. The x-member has tabs that go between the floor pan and the rockers. At that point you need to cut the pan there and lift it to get to those tabs on top of the rockers. Once the new X-member is in then lay and weld those cut areas back down.
Not real easy but very doable.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Torsion bar crossmember [Re: rocksmopar] #1682639
10/09/14 12:11 AM
10/09/14 12:11 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
If it isn't a platinum resto, the caps from Auto Rust technicians make the job a cinch, and stronger than OEM.
Rick
Re: Torsion bar crossmember [Re: moparmarks] #1682640
10/09/14 12:19 AM
10/09/14 12:19 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i never tried it that way.
its good to know it will work as i have a car
with a good floor and a rusted out torsion member myself.
i was planning on drilling the floor out of the car..
Re: Torsion bar crossmember [Re: flypaper] #1682641
10/09/14 12:32 AM
10/09/14 12:32 AM
moparmarks Offline
moparmarks  Offline
Ya sure saves a lot of work.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Torsion bar crossmember [Re: moparmarks] #1682642
10/09/14 06:14 AM
10/09/14 06:14 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Wow, and I was worried about putting a notch in my crossmember, so I could run an automatic overdrive. You guys that have to deal with rust, my hat goes off to you!
Re: Torsion bar crossmember [Re: jbc426] #1682643
10/09/14 06:15 AM
10/09/14 06:15 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Added a little on top to help it out.
Re: Torsion bar crossmember [Re: moparmarks] #1682644
10/09/14 11:19 AM
10/09/14 11:19 AM
eastern, pa.
cudabitten Offline
cudabitten  Offline
eastern, pa.
Only problem for this fix is you will be welding out of position(upside down). This was always the hardest thing for me during my restore.
