Re: Edelbrock performer or Thunder AVS?
[Re: PJM]
#168253
12/15/08 11:25 PM
12/15/08 11:25 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Fresh originals will cost 3,500.00 and up, however clones work just as well and will feed a 528 just fine if jetted properly. I sell them for $1,200.00 a set fresh and ready to go, see attached pic, these are built to order, not on the shelf. What's nice about them is that all original air cleaners, fuel lines, and linkage works on them because vintage small throat tops and reproduction OE Hemi side linkage are used. The bases are new Edelbrocks so all of the new jet & metering rods EB sells can be used in them. You'll likely find that using them in conjunction with other stock componants will result in one of the lowest cost combos as well.
[Re: ScottSmith_Harms]
#168254
12/16/08 02:47 AM
12/16/08 02:47 AM
Posts: 4,179 California
mickm
California
with all respect to scott, (and i have the utmost respect for him and his work), $1200 is still a pile of cash. if i could, i would go for it.
but i have 2 thunders on my engine, and they work well. yes, linkage and such has been an issue, but i have tried to retain a stock look. i use the fuel lines from tim at FHO, and i think its his stock looking linkage as well, (with a longer turnbuckle screw in the middle), and all in all it works well. have had to fabricate some parts for the linkage, but that's the game.
again, if i had the cash, i would go with scott's setup. but short of that, the thunders work well. tim at FHO uses them as well.
[Re: mickm]
#168255
12/16/08 02:57 AM
12/16/08 02:57 AM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, no problem at all brutha! Sales pitch aside, Thunders (or Holleys, or others still) will work, some better than others. My take on it is simply that the stock style AFB's will be quite adequate for a street strip 528 if setup right, heck the FAST racers run mid 10's with them on big inch 750hp plus Hemis all the time. Performance aside, IMO the neatest part is that they allow you to use of all original/reproduction linkage/fuel lines/aircleaners, etc. requiring zero mods. No, $1,200.00 isn't play money, but a pair of new Thunders aren't free, and niether is custom linkage, custom fuel lines, and especially air cleaners, short of making it all yourself you'd likely spend the same money either way you went. Not to mention that down the road stock style parts retain thier value better in most cases. So, my opinion is the old, "If it ain't broke, don't fix it" take on the subject.
[Re: mickm]
#168256
12/16/08 09:42 AM
12/16/08 09:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I would think that if somebody has the cash to dump into a hemi $1200 would be an easy buy.
[Re: Mr.Yuck]
#168257
12/16/08 01:24 PM
12/16/08 01:24 PM
mickm
California
like everything else, it depends. it's one thing to plan it up front, know what kind of cash you have and go at it from there. when i bought my car, replacing carbs wasn't in the budget, and i did have a budget. would have been nice not to, as like i said above i would have gone for a setup like this.
but mine already had a good air cleaner as well, so with a set of carbs like this, chuck another $650+ on the pile for one that fits the setup. it just keeps going, and everyone has a limit. well, most everyone...
[Re: PJM]
#168259
12/16/08 04:50 PM
12/16/08 04:50 PM
Mr.Yuck
Brookeville, Md
Isn't it funny. If you have a Hemi you must be a Rockefeller! I am not trying to bash anybody but I hate that mentality. Whenever I buy general parts I tell people its a 318 car so the price for the same part does not triple. Thanks for the responses!
I'm just saying in general a hemi is about 3 to 5x the cost of a wedge. So and extra 1200 for a nice matched set of carbs seems pretty fair. I just donked off $2100 for a 6-pack set-up so $1200 seems cheap to me...hahaha
[Re: PJM]
#168262
12/16/08 09:37 PM
12/16/08 09:37 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
I had the 750 performer on my crate 500 and really struggled,got an AVS 800 and was better straight away
For a 500 Cube engine with a single 4 barrel the bigger AVS is a better choice.
