71 Duster 340 Steering column #168178
12/15/08 08:34 PM
12/15/08 08:34 PM
Maryland
O
otrAlive Offline OP
otrAlive  Offline OP
O
Maryland
Looking for help on removing the steering column from my 71' Duster 340. The master cylinder, no power booster, has been removed. I know that it has a collapsible column and care needs to be taken there. Do I just remove the roll pin to separate the steering shaft from the gear box then unbolt it from the firewall?
thanx, Floyd
Re: 71 Duster 340 Steering column [Re: otrAlive] #168179
12/15/08 08:41 PM
12/15/08 08:41 PM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
There's some bolts under the dash that have to come out and wiring disconnected also.
Re: 71 Duster 340 Steering column [Re: dmerc] #168180
12/15/08 09:09 PM
12/15/08 09:09 PM
Maryland
O
otrAlive Offline OP
otrAlive  Offline OP
O
Maryland
OK, I know there's the two column wiring connectors and the bracket that secures the steering column to the dash.
Thanks for the info, it's appreciated...
Floyd
Re: 71 Duster 340 Steering column [Re: otrAlive] #168181
12/15/08 09:25 PM
12/15/08 09:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
3 bolts on the firewall inside the car..
Tony
70 AARCuda Vitamin C
