Re: Anyone Running a Stroker 440 (496CID) With a 6-Pack
[Re: 73challenger]
#168173
12/15/08 09:12 PM
12/15/08 09:12 PM
Posts: 406 California City, CA
dart440
California City, CA
Hi,
Is Anyone Running a Stroker 440 (about 500CID) With a 6-Pack??? What mods did you make/jet sizes, etc??? What initial/total timing are you running?
A friend has just put together this (496CID) combo and is having problems. He is running the same 6-pack as he was on his 440. He is running a 4-speed and 3.91s, and it's in a 71 Cuda.
Not sure of what cam or other mods he has made. He said he was running 9:1 CR.
Thanks, Chuck
When you work on Spaceships for a living, how bad can a workday be?
Re: Need some help getting my distributor in
[Re: SPWC]
#168174
12/16/08 01:08 AM
12/16/08 01:08 AM
Posts: 3,903 Oregon
hooziewhatsit
Once you have #1 on TDC, if the slot that drives the distributor doesn't let it point to #1, you'll need to move it so it does. There's no guarantee the previous owner didn't move the oil pump drive shaft, which would change where the disty points.
