Looking for Fiberglas shop in N.E. Ohio #1681311
10/03/14 01:01 PM
10/03/14 01:01 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Need to mate a scoop to a 'glass hood for our 70 Charger.
Anyone know of a shop that has experience near Cleveland??
Thanks, Joe
Re: Looking for Fiberglas shop in N.E. Ohio [Re: jlatessa] #1681312
10/03/14 03:09 PM
10/03/14 03:09 PM
pa.
dan9 Offline
dan9  Offline
pa.
I would think any of the boat places along the lake could direct you.
Re: Looking for Fiberglas shop in N.E. Ohio [Re: dan9] #1681313
10/03/14 04:46 PM
10/03/14 04:46 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Good idea...I'll ask around
Re: Looking for Fiberglas shop in N.E. Ohio [Re: jlatessa] #1681314
10/03/14 05:33 PM
10/03/14 05:33 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Why not do it yourself?
A little matting, some resin, rubber gloves and a small roller and your in business.
Never did any glass work myself but managed to switch scoops on my car, been 130+ and it's still there
It really is not difficult at all. Ever do paper mache?
Re: Looking for Fiberglas shop in N.E. Ohio [Re: roadhazard] #1681315
10/03/14 05:55 PM
10/03/14 05:55 PM
BDW Offline
BDW  Offline
Good advice,
Nice thing about fiberglass, compared to welding, if you mess up, just grind it and do over.
Pretty much same process as bondo, which everyone has tried, and succeeded.
Re: Looking for Fiberglas shop in N.E. Ohio [Re: BDW] #1681316
10/03/14 11:49 PM
10/03/14 11:49 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
OK, I'll try it, if worse comes to worst, I can always punt.
Thanks, Joe
Re: Looking for Fiberglas shop in N.E. Ohio [Re: jlatessa] #1681317
10/03/14 11:58 PM
10/03/14 11:58 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That's the old spirit!
Go to youtube and see if there's any video's. It'll give you some general direction. Basically you don't want to over use the resin and roll the air bubbles out.
Make sure your well ventilated or your face will look like this for an hour or so
Re: Looking for Fiberglas shop in N.E. Ohio [Re: BDW] #1681318
10/04/14 12:04 AM
10/04/14 12:04 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Good advice,
Same goes for welding actually. Grind weld fill
Now wood on the other hand.............
Re: Looking for Fiberglas shop in N.E. Ohio [Re: jlatessa] #1681319
10/06/14 12:06 PM
10/06/14 12:06 PM
pa.
dan9 Offline
dan9  Offline
pa.
As they said fiberglass is pretty easy to work with. Be sure you cut the pieces you will need before you mix the resin. You will nee multiple layers. Use a small roller to smooth out the air bubbles. The most important part is to protect yourself when grinding and sanding. It is not good for you. If your scoop has a finished flange on it and doesn't need to be blended in you could use Vette Bond or panel bond , the stuff they glue Corvette panels together with. It mixes up like Bondo.
