2005 grand caravan rear hatch issue #168105
12/15/08 05:29 PM
12/15/08 05:29 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
The rear hatch opens using the key, but it does not open with the key fob button or the dash switch.
I was wondering if anyone has run into this problem.
Thanks for any help!
Re: 2005 grand caravan rear hatch issue [Re: pacifica] #168106
12/16/08 12:17 PM
12/16/08 12:17 PM
Saskatoon Sk, Canada
Mark340A66 Offline
mopar addict
Mark340A66  Offline
mopar addict
Not on an 05, but my wife's old 94 had the remote release fail a couple of years ago. A buddy's 2002 went about the same time. I'm assuming it's pretty expensive repair.
Mopar or No Car: Sold Nov/06 1970 Challenger 340 4bbl (A66 code), A833 4 speed, 3.23 SureGrip all numbers match. 03 Dodge SX 2.0 R/T 2.0L HO(CDN Neon R/T) Black w/Grey Leather, Sunroof
Re: 2005 grand caravan rear hatch issue [Re: pacifica] #168107
12/16/08 12:38 PM
12/16/08 12:38 PM
moparmandc Offline
moparmandc  Offline
probably needs a lock acuator i think it is made in the latch so you will need a latch asuming it is getting voltage and ground when the switch is pressed
Re: 2005 grand caravan rear hatch issue [Re: pacifica] #168108
12/16/08 01:41 PM
12/16/08 01:41 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
Power lift gate or manual ?
Re: 2005 grand caravan rear hatch issue [Re: Blown71X] #168109
12/16/08 08:52 PM
12/16/08 08:52 PM
N.E.Ohio
P
pacifica Offline OP
pacifica  Offline OP
P
N.E.Ohio
It is a power hatch. It is my inlaws vehicle.I'll check it out the end of the week. Thanks
Re: 2005 grand caravan rear hatch issue [Re: pacifica] #168110
12/17/08 12:56 PM
12/17/08 12:56 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Should be a flash available for that concern.
