Correct package shelf underlayment.. #1680906
10/02/14 11:27 AM
10/02/14 11:27 AM
NJ-USA
HPMike Offline OP
HPMike  Offline OP
NJ-USA
Finishing up a 69 Hemi Coronet R/T...
Does anyone know if the correct underlayment is available for the rear package shelf? The stuff they sell isn't close...
I dont have an original here to compare or I can probably come up with something close..
Seems like black fiber board around 1/8" thick...
Anyone?
MB
Re: Correct package shelf underlayment.. [Re: HPMike] #1680907
10/02/14 12:09 PM
10/02/14 12:09 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I have a piece of my original package shelf left and it has a black felt like material about an eighth of an inch thick on the bottom. It is scored in areas where optional equipment (defroster/speaker) cutouts would have attached.
Re: Correct package shelf underlayment.. [Re: Pynzo] #1680908
10/02/14 05:39 PM
10/02/14 05:39 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
What is that stuff? The samples I've seen look like very soft black paperboard that tears easily like newspaper.
Jim Fillmore
Detroit Muscle Technologies
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Correct package shelf underlayment.. [Re: 71TA] #1680909
10/02/14 06:07 PM
10/02/14 06:07 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I'm not sure but I can send you a piece. Feels like a cross between paper and felt.
Re: Correct package shelf underlayment.. [Re: Pynzo] #1680910
10/03/14 10:50 AM
10/03/14 10:50 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Felt paper
Re: Correct package shelf underlayment.. [Re: 71TA] #1680911
10/03/14 12:07 PM
10/03/14 12:07 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Can your company reproduce it? I've purchased some of your gaskets and a gas tank pad before and they're top notch stuff. I'd definitely like to get a good package tray underpayment.
Re: Correct package shelf underlayment.. [Re: Pynzo] #1680912
10/03/14 05:48 PM
10/03/14 05:48 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
That paper is made from unobtanium. Some materials are just not available anymore. I've been researching for 2 years to find a very similar material for that and for some other similar brown paper. The brown paper is called "brown asbestos felt". Yep the stuff on the firewall and kick panel insulation and the gas tank pads are asbestos. They have the big A in a circle logo from Armstrong. The same Armstrong flooring that went bankrupt because of asbestos insulation products and tile flooring.
I was actually in contact with a company today to see how they were coming with samples of my fake "brown asbestos felt" paper. If the samples look good I'll have to buy 1/4 semi load of the stuff for them to make it in qty. I asked if they can do a similar black version like your application.
