Dodge Monaco C Body Wheel width? #1680873
10/02/14 01:08 AM
10/02/14 01:08 AM
Maine
1965Monaco Offline OP
Maine
I have a newly acquired '65 Monaco and would like to put on some wider, steel wheels with dog dish caps.
Can someone let me know the widest wheel/tire combo for a '65 C-body?
thanks
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680874
10/02/14 01:45 AM
10/02/14 01:45 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I have 275/60/15's on the back of my 66 C on an 8" rim with 4" BS.
Ideally I would go with 4.5" BS.
235/70/15 on the front on stock C-body road wheels which are 6" AFAIK.
Kevin
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680875
10/02/14 01:46 AM
10/02/14 01:46 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Don't know how wide you can go, but be aware the '65 "dog dish" hub caps are 10" VS. '68 & newer being 9-1/2" in diameter.
Re: Dodge Monaco C Body Wheel width? [Re: 6bblgt] #1680876
10/02/14 09:36 AM
10/02/14 09:36 AM
Maine
Maine
Awesome, thank you!
Re: Dodge Monaco C Body Wheel width? *DELETED* [Re: 1965Monaco] #1680877
10/02/14 09:39 AM
10/02/14 09:39 AM
Maine
Maine
Post deleted by 1965Monaco
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680878
10/02/14 09:43 AM
10/02/14 09:43 AM
Maine
Maine
Twostick, do you have the rear lifted at all?
I'd like to lift mine up just a bit so it sits just a little higher than the front. Any suggestion for how much to do, and how?
I assume just longer shackles??
thanks again!
Re: Dodge Monaco C Body Wheel width? [Re: 1965Monaco] #1680879
10/02/14 12:01 PM
10/02/14 12:01 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
No lift, stock springs.
ESPO will sell you new springs with 1 or 2 inches more arch. A spring shop might be able to re-arch yours but I've heard steel has a "memory" and the spring will slowly but surely settle back to where it was.
http://www.springsnthings.com/
To properly re-arch would require heat treatment to re-program the spring if you will.
Kevin
Re: Dodge Monaco C Body Wheel width? [Re: Twostick] #1680880
10/03/14 12:13 AM
10/03/14 12:13 AM
Maine
Maine
Ok, I'll check it out. Thanks!
