lose power steering at low RPMS 68 charger
#1680742
10/01/14 06:27 PM
10/01/14 06:27 PM
Posts: 389 kansas city, mo
rave_12000
kansas city, mo
Got tired of the leaks, so I took the upper valve assembly off my power steering sector (68 charger). cleaned up and put back together...then it had no power steering at low rpms...rev it up and there is power steering. I loosened up the two bolts and tapped the valve assembly around a bit to try to adjust, which only accomplished breaking an ear off. So, I put on a whole new assembly that is super clean...still loses power assist at low rpms. strange in that it was fine before, just leaked. Pump seems to be circulating fine. 68 TRW pump.
any ideas guys?
thanks a bunch, mike
Re: lose power steering at low RPMS 68 charger
[Re: rave_12000]
#1680743
10/01/14 06:39 PM
10/01/14 06:39 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Define low RPMs, my AAR will do it at times but only if it is about to stall 500 RPMs or less (still chasing a flucuating idle scenario).
Careful, your character's showing!
[Re: rave_12000]
#1680745
10/01/14 07:29 PM
10/01/14 07:29 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Is it possible that the pump is actually a Federal unit...not a TRW ?? I ask because I had no lower(2000 RPM and less) assist on my '68 GTX and it was the pump. There is a big spring inside the pump that keep everything seated in the rotor/valve part of the pump.....and it had broken. I can't for the life of me think how you could have done something to the box by removing the valve unless a piece of old o-ring fell inside one of the ports. Usually you MIGHT have to tap the valve a bit either way to center it so there won't be any "self steer", but you shouldn't lose pressure.
[Re: rave_12000]
#1680747
10/02/14 03:07 AM
10/02/14 03:07 AM
Posts: 257 Way North Idaho
1KoolBee
Way North Idaho
Exact same prob with my '68 Bee with a Federal pump. I swapped the Federal pump for a 69 Saginaw pump on my Bee & drove it for several years and never had a problem with it. Later, I rebuilt & restored the original '68 pump & put it back on & the problem returned. The vanes and springs seemed fine but the rotor slots appeared to be worn too wide. My theory is that the grooves in the rotor where the vanes ride wear out & get sloppy & it loses pressure. If if your car is a driver, I'd just bolt on a Saginaw pump & forget about it. If its a restoration, you may have to find a suitable donor pump for parts or have your machinist weld up the slots in your Federal pump's rotor & re-cut the grooves.
'68 Bee 383/TF/Factory Air...high school sweetheart '67 GTX Clone project,500 six pack,Hemi4-speed,Dana 05 Dodge Viper, 505 V-10, 6-speed Tremec
