Re: Four link and mini-tub advice...
[Re: ryangtogtx]
#1680661
10/01/14 02:31 PM
10/01/14 02:31 PM
Posts: 1,178 MN
ryangtogtx
MN
[Re: ryangtogtx]
#1680662
10/01/14 09:30 PM
10/01/14 09:30 PM
Posts: 1,301 Penna
70satelliteguy
Penna
"Any advice or pictures would be greatly appreciated. Thanks. " Don't have any advise but your shop is impressive I believe you could eat off of the floor Mike
[Re: NTOLERANCE]
#1680664
10/01/14 11:29 PM
10/01/14 11:29 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
The nature of a four link install almost makes a full on tub job make more sense. It could certainly be done , but to get optimum length bars and angles I think the back seat is a goner.......and as long as you are in that deep , why not stuff some meat back there. I am wrestling with that decision for my A body and the least painful would be ladder bars. I will exhaust a bit more effort on the leafs , but getting them to hook consistently is looking like a problem. If I do go four link , I will also go big tire.
[Re: ryangtogtx]
#1680665
10/02/14 10:17 AM
10/02/14 10:17 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
I'm looking for input for my dad. He wants to mini-tub and put a four link in his '63 Dodge MW. Any advice or pictures would be greatly appreciated. Thanks.
Not as adjustable as a full 4 link but better than a ladder bar.
[Re: GTS340]
#1680667
10/02/14 04:12 PM
10/02/14 04:12 PM
Posts: 1,552 Michigan
Kiddart
that looks like the best of both worlds. Have you made any passes with it yet?
Thank you Kiddart
[Re: Kiddart]
#1680668
10/02/14 04:47 PM
10/02/14 04:47 PM
GTS340
Romulus, MI
Not my car, just random internet pics. I plan to use this set-up on my Dakota. A few people on YB think rather highly of the Ultralink. It was appealing to me, takes about the same amount of real estate as a ladder bar but offers more adjustment options, more could be had by redesigning the brackets.
[Re: smokinwoody]
#1680671
10/02/14 06:45 PM
10/02/14 06:45 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
it's a 63 Dodge MW..
[Re: smokinwoody]
#1680672
10/02/14 08:24 PM
10/02/14 08:24 PM
Posts: 1,401 Wi.
old_racer
Wi.
it's a 65 Dodge MW..
isn't that a picture of a 63 dodge??
[Re: ryangtogtx]
#1680673
10/02/14 10:15 PM
10/02/14 10:15 PM
Posts: 9,863 MI, usa
dvw
MI, usa
I'm assuming this is mainly a street car. Why not Mini-Tub and leaf springs? Works well on the street and good for low 10 second ET's. Ladder bars work excellent in this venue but aren't as street friendly. But they would allow you to keep the back seat. Doug
[Re: old_racer]
#1680674
10/03/14 04:00 AM
10/03/14 04:00 AM
smokinwoody
somwhere
sorry, Typo...yes 63
by the way, this car will see mostly street duty and an occasional trip down the strip...the engine is a 499 rebuilt to run on 93 pump gas ..big HP and torque..shouldn't weigh more than 2800lbs due to acid dipped fenders and doors and being completely gutted..plus the use of Chrome Moly Steel for cage, suspension and other structural pieces...
[Re: ProStDodge]
#1680678
10/03/14 09:35 PM
10/03/14 09:35 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Unless it is going to be 80% race car, I would go with the mini tubs and cal-tracs. A four link will take away some of the streetability.
Yes a 4-link can be driven on the street, but for the slight ajustability advantage, it may not be worth sacrificing the better ride of the leaf springs.
A consideration for a "street car" is a triangulated 4 link, similar to a G body or a Mustang. I actually have that under a Challenger. I used Mustang type arms with urethane ends and the end can turn. Built custom brackets. The triangulated bar eliminate the need for a locator or a wishbone. With a good shock, the ride is 10 times better than buggy springs and at the track, a 4 bar is a 4 bar
Monte
