Re: What brand voltage Reg. to get.
[Re: 540challenger]
#168063
12/15/08 05:26 PM
12/15/08 05:26 PM
RapidRobert
point or electronic reg? If the "standard" brand you have is charging well(& those figures look good) may I ask why you would not want to just keep it in there?
[Re: Pacnorthcuda]
#168066
12/15/08 11:52 PM
12/15/08 11:52 PM
Posts: 2,826 NY usa
540challenger
NY usa
I haven't bought a VR for many years but as I recall "Wells" is the el-cheapo and "Standard" made pretty good stuff. I tried several years ago and noticed some variation in their operation even from identical brands, so I adopted the 'use whatever produces the charging voltages I like' approach.
Ya wells is the cheap stuff i used to work for an auto parts company that sold some of there stuff was junk other things were ok.
I never had a problem with standard before they ahve 3 lines
tru tec = cheap, standard= middle of the line and blue streak= top of the line stuff. Maybe i will just have to keep trying different regs to get the voltage like you said.
[Re: 540challenger]
#168067
12/16/08 12:19 AM
12/16/08 12:19 AM
RapidRobert
I reread your post & 13.5 is good on the high end but the 12.5 at idle is not enough & the lights are dimming.
[Re: 540challenger]
#168068
12/16/08 01:34 AM
12/16/08 01:34 AM
Posts: 5,186 Wherever I am.
Junky
Wherever I am.
I just had my alternator professionally rebuilt put a new reg Borg warner made in china it charges as high as 14.9 . and as low as 13.5 when idling at 750 rpm.
I put back my old reg not sure on the brand i think standard made in the use and it only charges as high as 13.5 and as low as 12.5 at a low rpm around 750 rpm
My new Denso alternator charges up to 14.9 right after start up, then settles down to 14.2 (constant) after a few minutes. The colder it is outside the higher the alternator will charge by a couple of tenths. I have no worries. The Denso has a built-in regulator.
Before the Denso, I ran a voltage regulator from Autozone, with a stock alternator. The highest it would charge was 14.7 after start up, then settle to 14 volts above 1,000 RPM's, 12.5 at idle.
[Re: Junky]
#168069
12/16/08 08:38 AM
12/16/08 08:38 AM
Posts: 2,826 NY usa
540challenger
NY usa
mine never settled down it stays at a nice finger crossing 14.9 while crusing.
[Re: Junky]
#168071
12/16/08 12:46 PM
12/16/08 12:46 PM
Posts: 2,826 NY usa
540challenger
NY usa
Are you sure the gauge is working correctly? It may be reading high. Batteries will take 15 volts OK, but that's about it. That's why 14.9 for a short time is not a worry. My "guess" is that 14.9 constant is OK too. This is assuming that the wiring is up to par. Hopefully an expert on the subject will chime in so we both know for sure.
I'd try yet another brand of voltage regulator. I know that two different regulators I ran were something like three tenths off from each other. One was from Autozone, the other from CarQuest.
Gauge checks out Good i went to the battery with a voltmeter to double check.
wiring under the hoood is 1 year old under the dash i still have to do.
I will being purchasing another reg this weekend.
Gets too dark early know i get off at 4:00 by the time i get home bye bye light.
THanks for the advise guys
