Re: Duster vs Scamp weight
[Re: DusterKid]
#1680576
10/01/14 12:11 PM
10/01/14 12:11 PM
Posts: 1,821 South Bend
John Brown
South Bend
NHRA says a 71 Scamp 318 is 4 pounds heavier than a 71 Duster with a 318. 2884 shipping on the Scamp, 2880 shipping on the Duster.
[Re: John Brown]
#1680581
10/02/14 12:00 AM
10/02/14 12:00 AM
Posts: 1,458 oklahoma
forphorty
oklahoma
Go to nhraracer.com then to Stock Car Classification on the left side under the Tech area. Click on Plymouth 1971 open the PDF file and scan down to line 253 and 255. Scan over to the right and read the weights under the engines with the single * . That is for the stock class cars. Note that the 340 Duster weighs 274 pounds more than the 318 Duster. I can't explain that either but I don't know any other way to find the weight online.
340 car would have a 727, 318 would have a 904. 340 would have an 8.75 rear, Standard trans 318 also has an 8.75. 318 auto has a 7.25. 340 car also has a beefier spring pack. Even so, 274 pounds sounds like a lot.
[Re: forphorty]
#1680582
10/02/14 12:13 AM
10/02/14 12:13 AM
Posts: 43,547 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Intake manifold, 4-bbl carb, exhaust manifolds, dual exhaust, wheels/tires/spare, and plenty of other heavier parts on a 340 as compared to a 318.
JB Rhinehart, Realist
A-Body's RULE!
[Re: RobX4406]
#1680584
10/02/14 09:59 AM
10/02/14 09:59 AM
Posts: 419 NY
F1Scamp
NY
I have a 71 scamp and a 71 duster. The 71 scamp has fiberglass bumpers, hood, seats, a 360 w/aluminum intake, and headers with short exhaust. The 71 duster has an all cast iron motor, full exhaust, all steel exterior and a full interior with a roll bar and subframe connectors. The duster is still 220lbs lighter.
Work In Progress- 71' Duster F.A.S.T.- 10.36@130 Smallblock Record Holder.
