Mechanicall VS dynamic compressio ratio and fuel ?
#1680531
10/01/14 01:06 AM
10/01/14 01:06 AM
Posts: 43,223 Bend,OR USA
Cab_Burge
I'm putting together a 440 block 505 C.I. bracket motor(4.350 bore x 4.300 stroke) that has a mecahical compression ratio of 12.60 with a dynamic compression ratio fo 9.08 to 1 according to United Machines on line calculator. The customer wants to mix 110 octane race gas with non ethanol pump gas that has 92 octane here in OR, my question is what percentage would be better for this motor, 50/50 (2.5 gallons of each) or 3 gallons race gas to 2 gallons pump gas for a 66.6 percent of race gas to pump gas I've never heard or paid any attention to dynamic compression ratio before coming onto this site many years ago This is a bracket car only, not street raced The solid roller cam is 108 LSA in at 106 on the intake and it has 269 @ .050 on the intake and 276@ .050 on the exhaust side, ported 440-1 with no flow numbers, single 1050 dominator on a 440-2 intake modded to fit the dominator carb. pattern. I am planning on dyno testing it next week on the local Studka dyno that has been calibrated recently, I'll ask to have it recalibarted for this motor, it has had a bunch of SB Chevys on it and may have been tweaked for those tests Just kidding on the tweaking
Re: Mechanicall VS dynamic compressio ratio and fuel ?
[Re: Cab_Burge]
#1680533
10/01/14 09:34 AM
10/01/14 09:34 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The fuel octane will be in direct proportion to the mix.(Edit; I stand corrected, non leaded only) No expert hear, but would think 50/50 should work. It would be nice to have a knock sensor on that dyno, just in case there was a hint of trouble. It would be good to have the extra octane in the tank though. Like for when my electric pump quit in the staging lanes just before the burnout! I didn't see it till the return road.
[Re: Cab_Burge]
#1680535
10/01/14 10:59 AM
10/01/14 10:59 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've never played with the dynamic pressure to octane to see what will work and be safe... plus different fuels will knock at different rates so start on the safe side... but I always try to reduce octane a little at a time... I see the engine running better and quicker with a lesser octane thats ends up being correct.. I wish there was a quick chart to use for a relation of dynamic to octane(and be close)... when I was talking with Dan on my SB he gave me a number for the dynamic that I should stay under for pump gas but I would have to find it
[Re: Cab_Burge]
#1680536
10/01/14 11:20 AM
10/01/14 11:20 AM
Posts: 12,153 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Will the dyno graph show detonation? A local racer told me a while back that he could identify detonation on the dyno by comparing the graphs. He said detonation makes the line much choppier. Any truth to that?
And have you thought about water/meth injection? It would be a lot less trouble than mixing and may save some money in the long run with the cost of race gas today.
Master, again and still
[Re: dogdays]
#1680538
10/01/14 03:57 PM
10/01/14 03:57 PM
Challenger 1
Cincinnati, Ohio
The 110 race gas is rated by the Research method. The 92 pump gas is rated by the (R+M) / 2 method. Rated by the Research method it'd be around 97 RON.
If the 110 has tetraethyl lead in it, adding the unleaded to it will not change the octane rating in direct proportion to the mix, because TEL follows the law of diminishing returns. So, the first gram changes the octane more than the second gram, which is more than the third gram, etc. This means that the last gram in the race gas turns into the first gram in the unleaded and the result is higher octane than you would expect, although lower than 110.
If the 110 is unleaded, then the octane changes in direct proportion to the mix. So 50/50 would get 97/2 + 110/2 = 103.5 RON.
R.
I believe 104 is as high as you can go without lead. And 104 is full of ethanol, way more than 10% to get it to 104. So I'm sure 110 is leaded.
[Re: Challenger 1]
#1680539
10/01/14 04:33 PM
10/01/14 04:33 PM
Posts: 8,166 Plymouth, MI
Blusmbl
Plymouth, MI
You can buy 110 unleaded all over town here in Detroit.
[Re: Blusmbl]
#1680540
10/01/14 04:43 PM
10/01/14 04:43 PM
Challenger 1
Cincinnati, Ohio
I said I believe. I think you should look closer, Here's Sunoco's list of unleaded fuels which I have been selling for years. Does not mean someone else is not selling 110 unleaded but I have never seen it. Show me some proof. Here's sunoco list. web page
[Re: MR_P_BODY]
#1680541
10/01/14 05:07 PM
10/01/14 05:07 PM
Posts: 21,831 Kirkland, Washington
Pacnorthcuda
I hear to stay under 8.5 dynamic for pump gas (92 here). On my motor thats 10.2 static--I was going to shave the AL heads to 10.5 but decided I better not.
My Voodoo cam intake closes at 60, thats pretty early, not too forgiving to high compression ratios.
[Re: Blusmbl]
#1680542
10/01/14 06:37 PM
10/01/14 06:37 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Same here, says right on the pump "unleaded".
[Re: justinp61]
#1680543
10/01/14 06:47 PM
10/01/14 06:47 PM
Challenger 1
Cincinnati, Ohio
What does a gallon of 110 unleaded cost?
[Re: Crizila]
#1680545
10/01/14 06:54 PM
10/01/14 06:54 PM
justinp61
W. Kentucky
Trust me, Sunoco 110 is leaded fuel. Don't are what the pump sez. Look on their web sight.
I don't see Sunoco mentioned in my post or the one I quoted. There are no Sunoco stations here.
[Re: MR_P_BODY]
#1680546
10/01/14 06:55 PM
10/01/14 06:55 PM
justinp61
W. Kentucky
Mike if you find the number Dan gave you can you post it?
[Re: Challenger 1]
#1680547
10/01/14 06:57 PM
10/01/14 06:57 PM
justinp61
W. Kentucky
The last time I bought any was six or so years ago and it was $6 a gallon then.
[Re: justinp61]
#1680548
10/01/14 06:58 PM
10/01/14 06:58 PM
Challenger 1
Cincinnati, Ohio
Thanks.
