Ignition Cylinder Removal #168049
12/15/08 03:01 PM
12/15/08 03:01 PM
Anonymous OP
Anonymous OP
Is the cylinder removal procedure almost the same as a GM? Steering/whl, lock/plate, directional switch, and key in run. And around one or three o'clock you press the pin to release the cylinder from the column? Thanks for your help. Like I said when I first joined up. I'm a GM Tech and this is my first old MOPAR..
Re: Ignition Cylinder Removal #168050
12/16/08 01:51 PM
12/16/08 01:51 PM
NM
74fish Offline
74fish  Offline
NM
Re: Ignition Cylinder Removal [Re: 74fish] #168051
12/16/08 10:30 PM
12/16/08 10:30 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
http://www.moparmusclemagazine.com/howto/155_0308_mopar_steering_column_rebuild/index.html
Actually, in the article they never removed the lock cylinder, they took the whole lock out.
But yes, you put the key in, turn it to run and put a small screwdriver or ice pick into the tab and the cylinder pops right out.
I just took the lock out of the glove box and used the same procedure but the tab is on the far end (from the key, anyway) of the cylinder.
Craig
