School me on a 98 Durango (things to watch for) #168035
12/15/08 02:52 PM
12/15/08 02:52 PM
Wisconsin
FFwithRT Offline OP
FFwithRT  Offline OP
Wisconsin
I am going to go test drive a 98 Durango 5.2L 160M on the clock new front susp parts. He is asking 2500. Sound ok? What should I be aware of when I drive it? Thanks in advance, Greg
FFGREG32@aol.com
Re: School me on a 98 Durango (things to watch for) [Re: FFwithRT] #168036
12/15/08 02:56 PM
12/15/08 02:56 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
FFGREG32@aol.com
they are notorious for junk front ends.. ball joints,tie rod,hubs.. and transmission issues..also caliper bolts strip out.. just my exp after buying one new in 99 and still own it...as a spare..
Re: School me on a 98 Durango (things to watch for) [Re: FFwithRT] #168037
12/15/08 03:28 PM
12/15/08 03:28 PM
Hatfield,Pa.
bigD Offline
bigD  Offline
Hatfield,Pa.
Transmission,rear end bearings on my 98. 2500.00 is not bad,its about what a dealer would give on a trade in.Like anything else.. stay up on the maint. and there pretty reliable,D
2015 Chrysler200s,2008 Charger R/T R&T,1999 Dakota R/T,1999 Viper ACR,1968 Charger R/T.
Re: School me on a 98 Durango (things to watch for) [Re: FFwithRT] #168038
12/15/08 04:31 PM
12/15/08 04:31 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
The big thing to always look for is the blown intake plenum gasket. Causes pinging, oil usage and poor mileage. The best way to check it is to shut the engine off and hold the throttle body wide open and look down into it with a flashlight. If you see a little puddle of oil the gasket is blown. We offer a repair kit (#7714) for it if you end up needing one. Other than getting about 13 mpg they are pretty decent trucks.
Good Luck & Merry Christmas!
Kevin @ Hughes
Re: School me on a 98 Durango (things to watch for) [Re: Hughes] #168039
12/15/08 05:33 PM
12/15/08 05:33 PM
My hovercraft is full of eels
DaveKanofsky Offline
My '99 that I bought new and took pretty good care of is getting pretty rusty in the quarters above the rear wheels. I have noticed that the tailgates tend to go around the bottom as well.
It's been good to us for 85K and counting miles.
MOPARS ONLY!
'69 Daytona, '16 Plum Crazy Challenger, '12 Durango, '01 Sebring conv't
Chaplain, Racers For Christ (http://teamrfc.org/)
John 3:17
Re: School me on a 98 Durango (things to watch for) [Re: DaveKanofsky] #168040
12/15/08 05:35 PM
12/15/08 05:35 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Wow rust that soon.. I have 235,000 and no rust so far...
Re: School me on a 98 Durango (things to watch for) [Re: 340dart4spd ] #168041
12/15/08 07:07 PM
12/15/08 07:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Like was said above, watch out for the front ends. Get the dealer to replace the ball joints if they are loose.
In 00 the 5.2 was replaced with the 4.7. They also got a new trans at that time. I havn't had any problems with mine in the two years I've owned it. I've gotten a best of 18mpg with my 4.7 however it's usually in the mid 15's.
Re: School me on a 98 Durango (things to watch for) [Re: FFwithRT] #168042
12/15/08 09:33 PM
12/15/08 09:33 PM
Cincinnati area
sch1966 Offline
sch1966  Offline
Cincinnati area
You may also want to ask questions about the heater core, fairly cheap part but major pain to replace.
Re: School me on a 98 Durango (things to watch for) [Re: sch1966] #168043
12/15/08 09:49 PM
12/15/08 09:49 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
The only problem Ive had with my 01 4.7 was the crank sensor. Other than that, I beat the hell out of it and it only has 91K on it. Drives like a dream....for a truck anyway
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: School me on a 98 Durango (things to watch for) [Re: 69L78Nova] #168044
12/16/08 05:40 PM
12/16/08 05:40 PM
Table Rock Lake Missouri
furious Offline
furious  Offline
We had a 98 for almost ten years. They were not the ones recalled for the front end, that came on later models.
I think the only real issue we had, not induced by my mods, was the A/C evaporator. I just performed regular maintenance, the driveline was awesome. Towed heavy boats, car trailers etc, no problems.
Oh, I did have the darndest time finding a tail gate leak that was filling the jack compartment every time it rained. I fought that a long time, it turned out to be the tailgate washer res hose had come off of the bottle inside.
Good luck!
Re: School me on a 98 Durango (things to watch for) [Re: FFwithRT] #168045
12/17/08 11:30 AM
12/17/08 11:30 AM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
I think Chrysler had a recall on the upper ball joints on the early Durangos and Dakotas. There were several front end failures that made the national news. Those were Durangos still under warranty that had failures. My 01 Dakota had a recall on the upper ball joints. Chrysler replaced the entire upper control arm when I took it in.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: School me on a 98 Durango (things to watch for) [Re: JOES4FORTY] #168046
12/17/08 11:49 AM
12/17/08 11:49 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Ball joints were recalled on the 99 or 00 modles, not the 98. I have had my 98 since new and it has 135K on it now.
I just redid my entire front end but it really only needed one bearing hub, an upper balljoint and idler arm.
I have replaced...
Starter
Alternator
Water pump
Heater core
Tailgate - rust
Front bumper - rust
Engine and trans are still going strong, I'm good about 3000 mile oil changes and yearly trans fluid changes.
My evaporator is now leaking and its as big a pain in the [Edited by Moparts - Keep it clean] to change as the heater core, if you need to do one I suggest doing the other.
Listen for a howl from the rear end and if the air is not working it could be that evil evaoporator. You said the front end was done but find out exactly what was changed, at that mileage I'd change the hubs. $2500 is not bad if the body is in decent shape.
Re: School me on a 98 Durango (things to watch for) [Re: GTXKen] #168047
12/17/08 02:36 PM
12/17/08 02:36 PM
Arkansas
GregGarner Offline
GregGarner  Offline
Arkansas
My 01 durango has had these two problems:
1) heater resistor went out (Every dodge I have has had this stupid resistor fail!)
2) Transmission sensor went out, wouldn't downshift to 1st anymore.
GregGarner
www.rt-eng.com
Home of the mopar solid state limiter adn tach repair kit
