308 bearing for A-833 Transmission #1680253
09/30/14 11:42 AM
09/30/14 11:42 AM
...gently down the stream
LAR_414 Offline OP
LAR_414  Offline OP
What are the options here? I see $29 to $100 bearings out there for the input shaft on an 18 spline transmission.
Why the differences?
Which bearing should I get?
Re: 308 bearing for A-833 Transmission [Re: LAR_414] #1680254
09/30/14 11:56 AM
09/30/14 11:56 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Go Timken you cant go wrong, although I am sure someone will tell me how they are junk now. Get one from Brewer, good service. Many bearings are repackaged and are made by the same company but I cant tell you who is related to who. The cheaper ones are probably Chinese or cheap Chinese and the more expensive ones are probably the better ones.
Careful, your character's showing!
Re: 308 bearing for A-833 Transmission [Re: mopar346] #1680255
09/30/14 01:39 PM
09/30/14 01:39 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
http://www.brewersperformance.com/proddetail.asp?prod=B308
These are an import bearing, but are manufactured by an ISO company, we have used over 2000 of these bearings with NO issues.
Wayne
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
Re: 308 bearing for A-833 Transmission [Re: LAR_414] #1680256
09/30/14 10:29 PM
09/30/14 10:29 PM
IMGTX Offline
IMGTX  Offline
Another Vote for Brewers. You won't have to worry about quality or if it is the right or or not.
Re: 308 bearing for A-833 Transmission [Re: IMGTX] #1680257
10/01/14 12:00 AM
10/01/14 12:00 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
$100 are the original SKF bearings.
Re: 308 bearing for A-833 Transmission [Re: rallye73] #1680258
10/01/14 11:05 AM
10/01/14 11:05 AM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
We do have a few USA bearings left if you so desire.
http://www.brewersperformance.com/proddetail.asp?prod=B308MRC
FAX 937-947-4419
