a727 noise on neutral #1680001
09/29/14 05:56 PM
09/29/14 05:56 PM
Czech Republic
69topless Offline OP
Czech Republic
Hi,
I have 69 Polara with 383 cui + 727 transmission. Recently, I noticed the noise coming from the transmission when neutral is selected. The noise is present only on neutral, no other gears including parking position. It sounds like some rotating parts rubbing against each other. I have tried to make a short video, but its quite hard to notice, its mostly noticeable at the end of video.
http://www.youtube.com/watch?v=C_Bywz_obuQ&index=1&list=UUr7aimYKZvtbqlji6JZJnNg
Transmission perform well as ever before and oil level is correct. Quick research indicate perhaps a bands needs to be readjusted. Any other thoughts? Thank you for your help
Re: a727 noise on neutral [Re: 69topless] #1680002
09/30/14 03:10 PM
09/30/14 03:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Remove the dust cover and check the converter bolts for tightness and the flexplate for cracks.
Bands have nothing to do with noises in Neutral.
