Vaccum gauge bouncing ... #1679662
09/29/14 01:27 AM
09/29/14 01:27 AM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Friend that I am helping out 383 has all of a sudden started to run poorly. After checking to make sure the cam isn't going flat he got it back together and I start see whats going on , he adjusted the timing without a light
Anyway when it's idling at about 900 rpm the vac gauge at the base of the carb has the needle fluctuating wildly, 10" or more, bring the RPM up to about 2k and the needle smooths out ?
The engine is fresh and it was running well till the other day it just started running poorly, carb is a fresh rebuilt Holley 650 DP that's about 30 years old.
I'm a little stumped and don't want to tear the thing apart further than necessary, a search online says sticky valves or a vac leak??? I sprayed starting fluid around the carb and intake thinking big vac leak but that turned up nothing ? There are paper gaskets on either side of the valley tin.
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679663
09/29/14 02:18 AM
09/29/14 02:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know I have always found anytime the vacum gauge needle bounces alot like 10 or more inches it is usually a mechanical problem. If it moves a good bit but drifts and dont bounce then it may be fuel. I know I had one once that drove me crazy as it was a 318 with a BBD carb and it would run bad and the vacum gauge bounce back and forth alot until it hit about 165 and then it smoothed out and the gauge got steady. Turned out to be the top of the hydaulic lifter popped above the retaining spring kinda making it act like a solid lifter and holding the valve off its seat. After it warmed up enough from the heat exspansion the lifter then let the valve close enough to run fine. I know its not just like your problem but its kinda in the idea ballpark. But you say yours smooths out with rpm no matter what temp ? Ron
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679664
09/29/14 02:30 AM
09/29/14 02:30 AM
Hello double R. Blown head gasket. Do a compression test
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679665
09/29/14 04:13 AM
09/29/14 04:13 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
Pull the rocker covers and check to see is a pushrod has punched through a rocker or two.
Re: Vaccum gauge bouncing ... [Re: Mcode69] #1679666
09/29/14 09:26 AM
09/29/14 09:26 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Or maybe a broken valve spring.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Vaccum gauge bouncing ... [Re: moparmarks] #1679667
09/29/14 12:07 PM
09/29/14 12:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Is it missing at low RPM IE: dead cylinder????
IF so you may be able to locate it by pulling the plugs wires one at a time the culprit will show no change in RPM, I would then pull the that valve cover and investigate further
Re: Vaccum gauge bouncing ... [Re: TJP] #1679668
09/29/14 12:14 PM
09/29/14 12:14 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
If it smooths out when you rev it up common wisdom is that its really loose valve guides. Never seen an engine do it though, anything I've seen is a burned valve or another issue and it never smooths out. I'm not sure how loose they would need to be to cause this.
Re: Vaccum gauge bouncing ... [Re: GTX MATT] #1679669
09/29/14 12:32 PM
09/29/14 12:32 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Heads have new valves and bronze liners, Comp springs, so I can't see it being the heads, especially consider who I had do the heads. It does have adjustable pushrods I can to adjust them again to rule out a valve hanging open. The weird thing is it was running so good, cam break in was perfect without any hiccups ...
I had the valve covers and the intake off and everything looked good, rotated the engine over to make sure everything was working fine.
Decks on both the heads and the block are fresh, Felpro 8519 gaskets. I hope it's not a head gasket because the block or head surface is probably torched by now ... uuugggghh
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679670
09/29/14 12:53 PM
09/29/14 12:53 PM
CT
CT
Head gasket should just read erratic no matter what in my opinion.
If you trust the machine work I'd say look into ignition and fuel, another carb if you can try it. Smell rich/funny??
Re: Vaccum gauge bouncing ... [Re: GTX MATT] #1679671
09/29/14 01:14 PM
09/29/14 01:14 PM
Assuming that is the problem (HG), At higher RPM's the head gasket is still blown obviously but the firing pulses being closer together masks/distorts the reading showing on the gauge
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679672
09/29/14 01:49 PM
09/29/14 01:49 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
Do a compression test, it will find the problem.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Vaccum gauge bouncing ... [Re: GTX MATT] #1679673
09/29/14 02:16 PM
09/29/14 02:16 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Changed out the distributor from a pertronics to points , didn't change anything, I moved the timing light onto all the plug wires and everyone is firing. I have a set of firecore wires I'm going to swap on to rule that out, bypassed the ballast and didn't change anything.
All he has is old, ugly carbs, it might be the carb on is so I guess I'm either going to have to buy one to try or use my new Thunder series 800. He's retired/fixed income and can't afford to buy new parts.
Compression test is first order of business.
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679674
09/29/14 02:50 PM
09/29/14 02:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Did you try pulling the plug wires one at a time as was suggested earlier? Throwing parts at it isn't the cure. You need to do the basic diagnosis first.
Re: Vaccum gauge bouncing ... [Re: stumpy] #1679675
09/29/14 04:11 PM
09/29/14 04:11 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Thanks for your help Stumpy , I know I can always count on you
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679676
09/29/14 05:21 PM
09/29/14 05:21 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
John no harm intended but this is kinda refreshing seeing you with a problem and not a solution!!!!
Ron
Re: Vaccum gauge bouncing ... [Re: RJS] #1679677
09/29/14 05:30 PM
09/29/14 05:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Ron
A common issue is being too close to the problem.
Sometimes the answers come when you haven't been working on it.
- Stu Harmon
Re: Vaccum gauge bouncing ... [Re: feets] #1679678
09/29/14 05:58 PM
09/29/14 05:58 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
Ron
I've got a good idea as to what it may be , the problem is in order to change out the offending part to prove that it is bad I'm the one that will have to supply the parts ... he's worked in a junkyard most his life and that is where his spares .... and sadly his storage techniques .... come from ... I asked for an iron intake to put on the motor to cover it up before we could get it installed in the car and he brings be one that is full of dirt ...
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679679
09/29/14 07:05 PM
09/29/14 07:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
JRR I was just wondering if you had isolated the problem because you didn't say in your post. You just listed parts you had changed.
Re: Vaccum gauge bouncing ... [Re: stumpy] #1679680
09/29/14 07:57 PM
09/29/14 07:57 PM
U.S.S.A.
JohnRR Offline OP
JohnRR  Offline OP
U.S.S.A.
I listed a bunch of parts ... the engine is a fresh build with maybe a couple hundred miles on it ... but the only part that was changed out was the distributor and that was because the owner is stuck in the 60's and doesn't like electronic ignition. I was concerned that maybe the the Pertronics and/or the Pertronics coil was damaged because it was being run with the ballast resistor still in place.
If you know of a way to test the Pertronics without replacing it with something else I'm all ears ...
Re: Vaccum gauge bouncing ... [Re: JohnRR] #1679681
09/29/14 08:53 PM
09/29/14 08:53 PM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
My brother put a Pertronix conversion in his M37 and pinched a wire direct to ground. He was worried about it and called tech support. Guy told him if it was working, then all is well. They generally work or don't.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
