Holley secondary metering plate mod- make adjustable ? #1677859
09/27/14 10:48 PM
09/27/14 10:48 PM
USA
SSAAHemiFan Offline OP
USA
I swear I read in one of the mopar mags that you could drill and tap the fixed secondary metering plates for jets and plug the stock holes ? I think Greg Rager did the article.
Can it be done or am I mixed up here ?
I have new 600 vacumm secondary carbs and I will be using them on a crossram
I don't want to use the thicker block or the billet block's that are available - has to look stock
Re: Holley secondary metering plate mod- make adjustable ? [Re: SSAAHemiFan] #1677860
09/27/14 10:58 PM
09/27/14 10:58 PM
I did it once way back. If you look at the plate you can see where to drill/tap. I dont remember where exactly as it was decades ago
Re: Holley secondary metering plate mod- make adjustable ? [Re: SSAAHemiFan] #1677861
09/27/14 11:03 PM
09/27/14 11:03 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I remember reading an article about that but the guy was doing the mods for his SS Ford 427 carbs.
I think it was an old issues of SS&DI
It involved drilling the plates and plugging the jet orifices on the bottom. Then you tap the holes for std.Holley jets and a small washer for correct spacing.
Gus
64 Plymouth Savoy
Dana 60
Re: Holley secondary metering plate mod- make adjustable ? [Re: fourgearsavoy] #1677862
09/27/14 11:09 PM
09/27/14 11:09 PM
Correct, you would need to plug the orifices that are already there for flow or you'd have near double volume. Trace the maze on the side & you'll see where to drill/tap. 10-32 tap iirc
Re: Holley secondary metering plate mod- make adjustable ? [Re: RapidRobert] #1677863
09/27/14 11:25 PM
09/27/14 11:25 PM
Rittman Ohio
Rittman Ohio
I hope this pic works
64 Plymouth Savoy
Dana 60
Re: Holley secondary metering plate mod- make adjustable ? [Re: SSAAHemiFan] #1677864
09/28/14 12:26 AM
09/28/14 12:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Why bother,you can buy a pair from Quick Fuel for less than fifty bucks.
Re: Holley secondary metering plate mod- make adjustable ? [Re: SSAAHemiFan] #1677865
09/28/14 06:44 AM
09/28/14 06:44 AM
Andrews,In. U.S.of A.
67_Satellite Offline
Drill and tap them for #10-32 thread. Get a small drill index and some brass set screws and make an adjustable set of "jets" without sealer on the threads to keep out of internal passages.
Re: Holley secondary metering plate mod- make adjustable ? [Re: 62maxwgn] #1677866
09/28/14 10:25 AM
09/28/14 10:25 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
ditto! I've drill and tapped them before but the quickfuel option is better. also lets you play with the idle feed restriction.
Re: Holley secondary metering plate mod- make adjustable ? [Re: 62maxwgn] #1677867
09/28/14 01:13 PM
09/28/14 01:13 PM
scratchnfotraction Offline
I used one on a 1850-2 600cfm carb and also added the adjustable vac pod from quik fuel.
the conversion plates are good and help keep size of the smaller 4160 carbs or a cheater plate in class rules that do not allow rear meter blocks.
my other 1850 got a AED 4160 to 4150 conversion that replaced the plate with a rear block and longer transfer tube along with a adjustable vac pod for less than 80$
another good upgrade is the billet meter blocks and mod the base plate for 4 corner idle less than 100$ or add a billet base plate for another 100$
Re: Holley secondary metering plate mod- make adjustable ? [Re: scratchnfotraction] #1677868
09/28/14 01:39 PM
09/28/14 01:39 PM
Rittman Ohio
Rittman Ohio
The Quickfuel kit with the notched float is the good choice
Linky
http://www.quickfueltechnology.com/metering-blocks-and-parts/side-pivot-float---billet-conv-kit.html
Gus
64 Plymouth Savoy
Dana 60
Re: Holley secondary metering plate mod- make adjustable ? [Re: fourgearsavoy] #1677869
09/29/14 12:32 AM
09/29/14 12:32 AM
USA
USA
thanks everyone - I posted because I was told (in error) that QF only offers a plate for center hung float's.
My fault for asking at the counter instead of researching it myself
