Re: Crank journal sizes opinions
[Re: OldMoparMan]
#1677737
09/27/14 11:52 PM
09/27/14 11:52 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would loose sleep over myself I like to start out with a fresh smooth true bearing surface. Give yourself peace of mind and cut it 10-10 Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: OldMoparMan]
#1677742
09/29/14 01:12 PM
09/29/14 01:12 PM
Posts: 2,677 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Journal sizes don't tell you much. You have to put in the block with the main bearings and check the clearance. That is what matters.
2011 Drag Pak Challenger
