A999 drum in a A904? #1677567
09/27/14 09:31 AM
09/27/14 09:31 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
A couple of questions, are the Aluminium drums for 904's based on the A999 5 clutch pack drum?
Second, what mods are required to run one of these drums in a 904?
Alan Jones
Re: A999 drum in a A904? [Re: LA360] #1677568
09/27/14 10:53 AM
09/27/14 10:53 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Do you know who's aluminum drum you're looking at? The steel jacket drum is a good option as the full aluminum one's wear fairly easy compared to a steel one.
Re: A999 drum in a A904? [Re: LA360] #1677569
09/27/14 02:55 PM
09/27/14 02:55 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
The TCS AL 904 drum is nice. They also sell a steel drum. They have a 24 spring return spring module too. As far as I know it drops in. You can ask their tech line to be sure.
http://www.tcsproducts.com/products/subcategory/15/
Re: A999 drum in a A904? [Re: LA360] #1677570
09/27/14 05:14 PM
09/27/14 05:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
In order to use the factory 5-disc drum in a 904 you also need the matching front pump (or at least the back half of one) for the added clearance.
Re: A999 drum in a A904? [Re: John_Kunkel] #1677571
09/27/14 05:46 PM
09/27/14 05:46 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
This swap reguires a different converter hub correct?
Re: A999 drum in a A904? [Re: John_Kunkel] #1677572
09/27/14 07:53 PM
09/27/14 07:53 PM
LA360 Offline OP
LA360  Offline OP
Thanks John, that ultimately answered my question. I am going to make most of the components for my trans and just needed to know whether to take my dimensions from a 904 or 999 high/reverse drum.
Does anyone have a picture of a A999 front pump? I am just curious to how much it is clearanced.
Alan Jones
Re: A999 drum in a A904? [Re: SpareParts] #1677573
09/27/14 07:57 PM
09/27/14 07:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, the "milled flat" hub is only on the A500 '96 and later.
Re: A999 drum in a A904? [Re: John_Kunkel] #1677574
09/28/14 12:29 AM
09/28/14 12:29 AM
gregsdart Offline
gregsdart  Offline
Would that be the same drum and pump in a lockup 904? Vintage 1987?
