Call me crazy or help me out...
#1677520
09/27/14 12:57 AM
09/27/14 12:57 AM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Wifes '00 4Runner has a wimpy 2.7 4 cyl. auto. in it. Very good condition and doesn't really need anything. It's OK around town but I really hate getting out on the highway with it. I'm thinking a 5.9 swap so it will get out of it's own way. What years are best? Seems like I read some year model trucks with manual trans, the computer will work with any trans. Thinking A518 w/ the 3 wire hook-up. Better suggestion? Brake upgrades are simple so that isn't a problem. Rear diff. is an 8" and lived well in some V-8 'yota 4x4 trucks I built. Looks like a long , cold, winter around here this year so I need something to keep me and the grandson busy. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
Re: Call me crazy or help me out...
[Re: None2Slow]
#1677525
09/27/14 09:21 PM
09/27/14 09:21 PM
Posts: 1,721 Eugene, OR
FuryBoy
Eugene, OR
Boy, those 2.7s are great with a 5 speed.
I think I would turbo charge it.
[Re: Jim_Lusk]
#1677527
09/27/14 10:39 PM
09/27/14 10:39 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
The answer varies depending on the laws of the state.
He's in Georgia...
As long as you'd don't ride your mule into walmart, aren't you pretty well good to go?
[Re: I_bleed_MOPAR]
#1677531
09/28/14 12:16 AM
09/28/14 12:16 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Tim I have seen a 302 Ford swap in a 02 Runner before and it seemed like an easy swap because it's much narrower than most other V-8's. I didn't get to talk to the owner and all I know was it wasn't a C6 or a regular C4 as far as my knowledge of Ford transmission identifying skills go. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: I_bleed_MOPAR]
#1677536
09/28/14 12:40 PM
09/28/14 12:40 PM
OzHemi
Garden Grove, CA
Push comes to shove I may wind up with a Furd motor again.
So a 302 is ok but a modern 5.3 LS with aluminum heads is not? Fair enough.
How about a 4BT swap?
[Re: fourgearsavoy]
#1677538
09/28/14 10:17 PM
09/28/14 10:17 PM
I_bleed_MOPAR
Buford, GA
Gus, I actually put a 5M-GE from an '85 Supra into a friends '84 4x4 back in the late 80s. Same deal- he bought the whole car for the engine/harness, ecm, and bellhousing (5 spd. in the Supra). We originally cut the core support for a crossflow radiator but he wound up putting a new support back in it and used a 3VZ radiator. he towed a bass boat (really heavy back then) and was really surprised at the power. I helped do 4 of these trucks total and did my '83 in the middle. The 2nd one I helped with was another good friend. After a year or so he decided he wanted a 7M-GTE in his but totaled the truck before we could do it. Oz, GM left a bad taste in my mouth years ago after I bought a '94 CC dually new. It had the 6.5 TD in it and was a nice truck until the dealer did the recall on it. It was all downhill from there including starting a lemon law buy-back and culminated in the truck burning to the ground early one A.M. (in the boonies headed deer hunting). The insurance inspector found a loose oil line to the turbo (replaced by the dealer the last time they worked on it) as the area where the fire started. Imagine my surprise when I found out that they were actually checking to see if I had burned the truck up. Tim
