Dual Ballast Ground Lug, Where does it go? #1677314
09/26/14 07:36 PM
09/26/14 07:36 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hi, I have a ground lug in my wire harness going to the dual ballast area. Checking my pictures, I do not see this lug going to the mounting stud, so I'm assuming it goes to the firewall? Good size ring lug, maybe 1/4 inch?
Re: Dual Ballast Ground Lug, Where does it go? [Re: cudabitten] #1677315
09/26/14 08:54 PM
09/26/14 08:54 PM
I'd see if you can find it on the diagrams at www.mymopar.com & if not I'd take off a batt cable & ohm the ring lug & then find the other end of it that is showing a reading
Re: Dual Ballast Ground Lug, Where does it go? [Re: RapidRobert] #1677316
09/26/14 09:03 PM
09/26/14 09:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
someone must have just run a ground to there? i'd do what my friend Robert suggested,
Re: Dual Ballast Ground Lug, Where does it go? [Re: mikemee1331] #1677317
09/27/14 05:13 PM
09/27/14 05:13 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
i saw in your other thread that your car has AC, so maybe the lug should go on the bottom wipermotor stud,with an extra nut to hold it in Place.good luck
Re: Dual Ballast Ground Lug, Where does it go? [Re: cuda-sweden] #1677318
09/29/14 12:38 AM
09/29/14 12:38 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
And this is the correct answer...As odd as it looks the factory used the wiper motor stud as the ground..B body as well...
Re: Dual Ballast Ground Lug, Where does it go? [Re: screamindriver] #1677319
09/29/14 10:13 AM
09/29/14 10:13 AM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
ground strap from firewall to rear head bolt! ?
Re: Dual Ballast Ground Lug, Where does it go? [Re: 71_deputy] #1677320
09/29/14 11:34 AM
09/29/14 11:34 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
guys, it's a 74... he is talking about the ground source for the reset intelock button. There is not any ground source on taped harnesses around firewall, but just 74s for that.
Blowers gets a similar wire source for ground, attaching to fiberglass box studs on firewall, but is not taped to any harness
the other one on our cars is the one on radiator core support for headlight harness, but that's all.
