HP/CI
#1676673
09/25/14 02:23 AM
09/25/14 02:23 AM
Posts: 4,457 Washington
madscientist
Washington
When do you ENGINE BUILDERS consider an engine a performance success? Is it HP/CI or do you just look at total power output?
Just curious.
Re: HP/CI
[Re: madscientist]
#1676674
09/25/14 11:26 AM
09/25/14 11:26 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Just curious.
if it don't blow up after two nitrous passes, I call it a success. My last two attempts haven't been successes( that is a lot of s's lol)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
Re: HP/CI
[Re: madscientist]
#1676676
09/25/14 01:02 PM
09/25/14 01:02 PM
Posts: 167 maryland
74yellowduster
maryland
Just curious.
just go off the time slips
Re: HP/CI
[Re: madscientist]
#1676678
09/25/14 01:43 PM
09/25/14 01:43 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Just curious.
IMO ...... You can't answer that unless you answer a lot of questions. NA? boosted? fuel type? power adders? budget? application? what? But today, a stock rebuild using basically stock short block components, mild stock-style cam and modern heads should do 1.05. From there it's budget and maintenance. Fairly reliable pumped up street muscle motors on pump gas should do 1.25 without breaking parts.
I built a NA single TB HEMI build for bracket drag racing that was 572", had a fair amount of head work, but was relatively low compression (11:1) that did 965 HP. That's 1.68 and I considered that pretty good for a motor that didn't require any special maintenance.
Once you approach 2:1 you better know what you're doing and have the time and $.
Re: HP/CI
[Re: 74yellowduster]
#1676679
09/25/14 02:50 PM
09/25/14 02:50 PM
Posts: 760 Canada
CTD5.9
Canada
Just curious.
So if the customer can't drive a drag car very well and has a slow time, the engine builder is useless? pretty much the worst way to tell success from an engine stand point. Too many variables that aren't the engine.
Re: HP/CI
[Re: Mopar_Rich]
#1676680
09/25/14 02:55 PM
09/25/14 02:55 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I agree with Rich, that is to open ended a question and there are way to many variables. But I am one of those dummies looking for HP over torque generally. But I will ad that the cylinder heads have a lot to do with the ultimate outcome of the build.
My last few engines have been over 2.0 but that is nothing these days. However we wanted reliability as much as power. Being a Super Class racer having something that was repeatable and reliable is the most important thing. My B1 was right at 2.1 and has been very reliable. It is nearing 400 passes now and will come apart this winter but only due to the aluminum rods. Still running as it has from the beginning.
The engine in the heads up car was a different deal all together. It was just under 2.7. But it had a very efficient set of cylinder heads, a very large bore and very short stroke. It made over 1300HP from just 497 cubes. Reliability was not as goal. Power was.
Re: HP/CI
[Re: Mopar_Rich]
#1676682
09/25/14 03:10 PM
09/25/14 03:10 PM
Al_Alguire
Las Vegas
If only a Predator set up could be close...Just don't think it will happen with these heads, at least the way we want. Looking like this is another 2.1 or 2.2 set up. Not bad but probably my mistake using so much stroke. But it ought to make a decent power number anyway. As has been pointed out the 4.5" bore limit is the killer here.
