axioms we can relate to
#1676473
09/24/14 10:16 AM
09/24/14 10:16 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Risk rises to the square of the rpm If you are not sure you torqued all the rod bolts, you didn't If you are certain that two changes will make you faster, the answer is probably not OK gang, add yours
Re: axioms we can relate to
[Re: 67_Satellite]
#1676477
09/24/14 01:37 PM
09/24/14 01:37 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Light is right, big is best
[Re: gregsdart]
#1676479
09/24/14 02:26 PM
09/24/14 02:26 PM
Posts: 7,494 Minnesota
Hemi_Joel
Minnesota
there is no replacement for displacement
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: oldiron]
#1676488
09/24/14 06:17 PM
09/24/14 06:17 PM
Hemi_Joel
Minnesota
I'd rather have bottle in front of me than a frontal lobotomy
[Re: dustergirl340]
#1676492
09/25/14 08:39 AM
09/25/14 08:39 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
I would agree with you, but then we would both be wrong.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
