70 Power wagon rear drum brake question
#1676220
09/23/14 07:20 PM
09/23/14 07:20 PM
Posts: 658 Dillsburg, PA
Wizard
Dillsburg, PA
I replaced the wheel cylinder and replaced the adjuster and that steel cable that connects onto the adjuster bracket but I cannot get the steel cable over the little metal piece that attaches the brake shoe and the spring goes. The steel cable seems to be to short that came with the brake kit I bought. I checked the length against the old cable that snapped and it is the same size. How do you get that steel cable over the metal piece where the spring goes into the brake shoe and what does this steel cable do? It does connect to the adjuster bracket on the bottoms of the brake shoes and it attaches up to the top of the post where the tops of the brake shoes come together
Wizard
Guns, God, and Country.
U.S. Veteran
Re: 70 Power wagon rear drum brake question
[Re: Wizard]
#1676221
09/23/14 08:39 PM
09/23/14 08:39 PM
Posts: 727 Cleveland Ohio
sportfury70
Cleveland Ohio
You should just have to lift the adjuster tab up and connect it to hook on cable.
The cable is for self energizing. (self adjusting)
[Re: sportfury70]
#1676222
09/23/14 08:46 PM
09/23/14 08:46 PM
Wizard
Dillsburg, PA
Yes, that is what I am trying to do and I have everything hooked up and the brake adjuster set to minimum to give me as much slack as possible but I am still about 1/2 short seems like of cable. I have the adjuster tab stretched to max while trying to get it over the cam that attaches to the brake shoe.
Wizard
U.S. Veteran
[Re: sportfury70]
#1676224
09/23/14 09:06 PM
09/23/14 09:06 PM
Wizard
Dillsburg, PA
Nah, I got the right kit as it had everything else in the kit for the rear drum. I will take a picture of what I have and post it and see if anyone can see something that way.
Wizard
U.S. Veteran
[Re: Wizard]
#1676228
09/23/14 10:30 PM
09/23/14 10:30 PM
Wizard
Dillsburg, PA
I don't know what the heck is wrong except I am just short 3/4 of cable. I have tried everything. Went to You Tube and not much there except few other types and watched them but doesn't have a 70 dodge brake drum change. What the heck? Turning into a 40 hour job now.. This should be simple. I checked the part number I bought against rock auto and its coming up with the right Carlson brake kit for it.
U.S. Veteran
[Re: Wizard]
#1676229
09/23/14 10:31 PM
09/23/14 10:31 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I don't see anything wrong, guessing the cable is too short. Have you checked the length against the cable on the other side?
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#1676230
09/23/14 10:32 PM
09/23/14 10:32 PM
Wizard
Dillsburg, PA
no, haven't pulled the other side off yet. Was doing 1 at a time but I am pulling my hair out and that's my last resort I guess. Here is pic of old cable I found when I pulled the drum off. Same length as new one!
U.S. Veteran
[Re: roe]
#1676232
09/23/14 11:53 PM
09/23/14 11:53 PM
Wizard
Dillsburg, PA
Yes, I have exhausted all possibilities of stretching as much play out of everything. I am taking everything back and see if I can get a longer cable. I see there is some rants about this when you plug it in MSN brake cable length on W200 seems people having same problem
U.S. Veteran
[Re: 76dodgeboy]
#1676235
09/24/14 08:09 PM
09/24/14 08:09 PM
Wizard
Dillsburg, PA
I solved the problem. Bendix cable H2106-2 is the part number fits beautifully and problem solved.
The kit I bought has the wrong cable in it. Too short. Checked out another kit from advance and also same problem. Went to a truck shop today and they gave me the Bendix cable and looked it up on e-bay and fits Dodge D200 and 350
U.S. Veteran
