70 Power wagon rear drum brake question #1676220
09/23/14 07:20 PM
09/23/14 07:20 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
I replaced the wheel cylinder and replaced the adjuster and that steel cable that connects onto the adjuster bracket but I cannot get the steel cable over the little metal piece that attaches the brake shoe and the spring goes. The steel cable seems to be to short that came with the brake kit I bought. I checked the length against the old cable that snapped and it is the same size. How do you get that steel cable over the metal piece where the spring goes into the brake shoe and what does this steel cable do? It does connect to the adjuster bracket on the bottoms of the brake shoes and it attaches up to the top of the post where the tops of the brake shoes come together
Wizard
Guns, God, and Country. U.S. Veteran
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676221
09/23/14 08:39 PM
09/23/14 08:39 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
You should just have to lift the adjuster tab up and connect it to hook on cable.
The cable is for self energizing. (self adjusting)
Re: 70 Power wagon rear drum brake question [Re: sportfury70] #1676222
09/23/14 08:46 PM
09/23/14 08:46 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Yes, that is what I am trying to do and I have everything hooked up and the brake adjuster set to minimum to give me as much slack as possible but I am still about 1/2 short seems like of cable. I have the adjuster tab stretched to max while trying to get it over the cam that attaches to the brake shoe.
Wizard
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676223
09/23/14 09:03 PM
09/23/14 09:03 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Is it possible you got a cable for front brakes or just the wrong cable ? Is there different size brake shoes for that model? If you have say 12" brakes but cable is for 11" Just trying to throw out so ideas.
Re: 70 Power wagon rear drum brake question [Re: sportfury70] #1676224
09/23/14 09:06 PM
09/23/14 09:06 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Nah, I got the right kit as it had everything else in the kit for the rear drum. I will take a picture of what I have and post it and see if anyone can see something that way.
Wizard
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676225
09/23/14 09:27 PM
09/23/14 09:27 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
pic 1
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676226
09/23/14 09:28 PM
09/23/14 09:28 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
pic 2
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676227
09/23/14 09:29 PM
09/23/14 09:29 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
pic 3
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676228
09/23/14 10:30 PM
09/23/14 10:30 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
I don't know what the heck is wrong except I am just short 3/4 of cable. I have tried everything. Went to You Tube and not much there except few other types and watched them but doesn't have a 70 dodge brake drum change. What the heck? Turning into a 40 hour job now.. This should be simple. I checked the part number I bought against rock auto and its coming up with the right Carlson brake kit for it.
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676229
09/23/14 10:31 PM
09/23/14 10:31 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I don't see anything wrong, guessing the cable is too short. Have you checked the length against the cable on the other side?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 70 Power wagon rear drum brake question [Re: 3hundred] #1676230
09/23/14 10:32 PM
09/23/14 10:32 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
no, haven't pulled the other side off yet. Was doing 1 at a time but I am pulling my hair out and that's my last resort I guess. Here is pic of old cable I found when I pulled the drum off. Same length as new one!
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676231
09/23/14 11:35 PM
09/23/14 11:35 PM
Central TX
roe Offline
roe  Offline
Central TX
pic 2
It's been a little while since I did my last set of drums but IIRC you should be able to remove the spring that's on the piece you're trying to connect the cable to. Then you'll have the slack to connect your cable. Then reconnect the spring. I always have to play as round with the pieces for a while when I do drums before I remember because I only had one vehicle with drums. Now I have two. I also seem to remember there being some give somewhere, like I could squeeze the two shoes closer together for the cable to be able to reach. Like I said, I generally play around with all of the pieces before I remember because it's been so long between doing drums.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: 70 Power wagon rear drum brake question [Re: roe] #1676232
09/23/14 11:53 PM
09/23/14 11:53 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
Yes, I have exhausted all possibilities of stretching as much play out of everything. I am taking everything back and see if I can get a longer cable. I see there is some rants about this when you plug it in MSN brake cable length on W200 seems people having same problem
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676233
09/24/14 01:12 AM
09/24/14 01:12 AM
Central TX
roe Offline
roe  Offline
Central TX
Have you pulled the non broken cable from the other side to compare the length to your new one? Might be worth a check before you return it. Just to verify the complaints you've found online
Re: 70 Power wagon rear drum brake question [Re: roe] #1676234
09/24/14 01:33 PM
09/24/14 01:33 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
That was going to be my question. What's the other side look like
Re: 70 Power wagon rear drum brake question [Re: 76dodgeboy] #1676235
09/24/14 08:09 PM
09/24/14 08:09 PM
Dillsburg, PA
W
Wizard Offline OP
Wizard  Offline OP
W
Dillsburg, PA
I solved the problem. Bendix cable H2106-2 is the part number fits beautifully and problem solved.
The kit I bought has the wrong cable in it. Too short. Checked out another kit from advance and also same problem. Went to a truck shop today and they gave me the Bendix cable and looked it up on e-bay and fits Dodge D200 and 350
Re: 70 Power wagon rear drum brake question [Re: Wizard] #1676236
09/24/14 10:03 PM
09/24/14 10:03 PM
Central TX
roe Offline
roe  Offline
Central TX
cool beans
