Steering pot coupler #167615
12/14/08 07:22 PM
12/14/08 07:22 PM
North Carolina
469runner Offline OP
North Carolina
How much wear is acceptable for the housing? I didn't feel any slop in the coupler, but the gasket was shot and most of the grease dried up, so I ordered new shoes, gasket, and cover from my local Dodge dealer. Upon disassembly and inspection I find some slight wear in the housing where the shoes ride. Does a slight amount of wear, enough to feel, warrent replacement of the housing itself?
Re: Steering pot coupler [Re: 469runner] #167616
12/14/08 11:40 PM
12/14/08 11:40 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
A little wear isn't a problem. If you hold the coupler still how much play is there on the upper shaft?
Re: Steering pot coupler [Re: stumpy] #167617
12/15/08 01:23 AM
12/15/08 01:23 AM
North Carolina
North Carolina
Very little movement, hardly noticable in fact.
Re: Steering pot coupler [Re: 469runner] #167618
12/15/08 08:33 AM
12/15/08 08:33 AM
a little movement at the coupler translates to much more movement out at therim of the steering wheel.
Re: Steering pot coupler #167619
12/15/08 09:55 AM
12/15/08 09:55 AM
Grand Prairie,Texas
Grand Prairie,Texas
I wouldn't worry about it. There is always a little movement because it's not a solid joint. Some cars use a rag joint and it has play with no problems.
Re: Steering pot coupler [Re: 469runner] #167620
12/15/08 04:57 PM
12/15/08 04:57 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
used the rebuild kits on both of my '65s. The difference is unbelievable. I thought that the steering boxes were worn out.
This is the land of the free because of the brave
Re: Steering pot coupler [Re: rbstroker] #167621
12/15/08 05:06 PM
12/15/08 05:06 PM
WV
JohnH Offline
JohnH  Offline
WV
Becareful not to put the shoes in side ways or you will have a lot of play like I did... also there is a spring clip to hold every thing together after you finish.. it is a must to get one.. he sells them here on this site.. try to find his email address..
Re: Steering pot coupler [Re: JohnH] #167622
12/15/08 05:42 PM
12/15/08 05:42 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I had the site bookmarked where the guy sold the clip as mentioned above, but I just went to the site and it's apparently gone.
Does anyone know if there is another source for those clamps to hold the seal on the top of the steering joint?
Thanks,
Darren
Re: Steering pot coupler [Re: Ludington1] #167623
12/15/08 06:26 PM
12/15/08 06:26 PM
scratchnfotraction Offline
should be able to get the spring,shoes,rubber,ring at the stealer...I mean dealer
thats where I gots mine
Re: Steering pot coupler [Re: scratchnfotraction] #167624
12/15/08 06:57 PM
12/15/08 06:57 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
Thanks, but that's not the clip being referenced. There was a guy who made a small spring/clip that once you had it all together and the rubber seal and stamped metal retainer on top of the coupler, this clip would go around the whole assembly to hold the metal retainer and rubber seal onto the coupler.
You're right, the coupler rebuild kit can be found at the dealer.
Darren
Re: Steering pot coupler [Re: scratchnfotraction] #167625
12/15/08 06:58 PM
12/15/08 06:58 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
I sold all of my clamps to a guy who was reselling them on Ebay as MainelyMopar or something like that.. (He is from Maine)
Re: Steering pot coupler [Re: ekim] #167626
12/15/08 09:46 PM
12/15/08 09:46 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
He's a member here, maybe he'll chime in.
Re: Steering pot coupler [Re: In_The_Pink] #167627
12/15/08 09:54 PM
12/15/08 09:54 PM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
I'd be interested in one, if we can track him down here or on eBay.
Re: Steering pot coupler [Re: Ludington1] #167628
12/15/08 10:42 PM
12/15/08 10:42 PM
those clamps are a bandaid. theres a right method to hold the stock clamp/gasket down tight to the coupler housing.
Re: Steering pot coupler #167629
12/15/08 11:10 PM
12/15/08 11:10 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
TSB
Re: Steering pot coupler [Re: Snoopy] #167630
12/16/08 12:32 AM
12/16/08 12:32 AM
Farmland, IN
Ludington1 Offline
Ludington1  Offline
Farmland, IN
TSB
Thanks Snoopy... and it seems like no matter how many times I think I have it on "the right way" it ends up loose again.
Sorry to the original poster if I got this thread too far off topic.
Darren
Re: Steering pot coupler [Re: Ludington1] #167631
12/16/08 08:25 AM
12/16/08 08:25 AM
I use a pair of pliers and crimp 2 tabs on the corners of the pot to hold it on,till all 8 tabs are crimped on the 4 corners
has allways worked for me
oh! that would be an aftermarket spring
Re: Steering pot coupler [Re: scratchnfotraction] #167632
12/16/08 10:45 AM
12/16/08 10:45 AM
Ontario, Canada
8
84Stepside Offline
84Stepside  Offline
Ontario, Canada
i just got done taking mine apart, man that pin in the shaft was in there and almost half of it was dust now and the one block too lol, no wonder my steering was shot, i had to use a press at work to get the pin out, i put a grease nipple in my coupler pot now for the future.
