93' 5.9 Magnum fuel pressure issue
#1676072
09/23/14 10:00 AM
09/23/14 10:00 AM
Posts: 4,867 Upstate, NY
MikeP
Upstate, NY
Hi all ! 1993 W250 5.9L Magnum. Was running rough, stumbles at idle, dogs out/back fires with any throttle. New I had a burnt plug wire. Did plugs, wire cap rotor. No improvement. Was messing with timing and decided to squirt a little gas into throttle plates and the engine smoothed right out. Couldn't hear the fuel pump come on plus the filter is on the pump in the tank, so I put a new pump and filter in. No improvement. I had fuel at the shrader valve on the rail. Went to Rock Auto under fuel and they listed a Fuel pressure regulator. There isn't one on this truck at the rail, Only SS braided line from hard line on frame to fuel rail. I disconnected it and had a piece of clear hose same diameter as male line inserted in to SS quick connect and turned on key. Plenty of fuel volume for 2 secs until the relay shuts it off. Put a guage on line and cycled the pump a couple times with key and could only get ~10 psi. During my troubleshoot I suspected voltage to pump, Ran a meter on line in and with truck running had 14.0 V. Cleaned all grounds. 1) What should the Psi be ? ~ 40psi? 2) Should I measure psi at Shrader vale on rail?(dont' have an adapter)Can I pull valve out like a tire shrader vale and plumb to guage? 3) Could it be plugged injector(s) ? Should I replace all of them?
Any advice appreciated !
"Think Pink" 67'Dart GT vert, 69' Newport vert, 67' Barracuda
and a pile of trucks 78'79'91'92 CTD
Re: 93' 5.9 Magnum fuel pressure issue
[Re: 3hundred]
#1676080
09/24/14 09:32 PM
09/24/14 09:32 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
92-93 magnums had the regulator on the fuel rail. In 94, they went to single line feed with the regulator in the fuel pump module.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 71yelladustr]
#1676083
09/25/14 01:12 AM
09/25/14 01:12 AM
Posts: 5,301 CA, Proprietor; The "PALOMINO"...
dynotune440
93 magnums were weird... 5.2 mag had an inline fuel filter and a return fuel line with regulator in fuel rail. 5.9 mag had no inline filter, returnless fuel rail, and fuel regulator in fuel pump module assembly... Bought a few of these trucks for cheap because of a bad pump...
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
Re: 93' 5.9 Magnum fuel pressure issue SOLVED
[Re: MikeP]
#1676085
09/27/14 09:13 AM
09/27/14 09:13 AM
MikeP
Upstate, NY
It was the ground. Siamesed splice right at pump plug then to Body. New pump has 50 psi. Thank you !
