cooper head gasket #1675925
09/22/14 10:16 PM
09/22/14 10:16 PM
NC
barracuda man Offline OP
NC
This is a new build Sb 360 13.5/14.1 compression.Seems the cooper head gaskets are not sealing.I sprayed them with cooper coat spray.The block is o-ringed.With the radiator cap off i can rev up motor and the water spews out and bubbles.Would you guys try the holomor stuff or buy new cooper head gaskets.looks like there is a sec stamp on gaskets.
Re: cooper head gasket [Re: barracuda man] #1675926
09/22/14 10:33 PM
09/22/14 10:33 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Never heard of that brand.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: cooper head gasket [Re: barracuda man] #1675927
09/22/14 10:33 PM
09/22/14 10:33 PM
NC
NC
I read someone used cometics on a o-ringed block with no problems.can't find the post.
Re: cooper head gasket [Re: DusterDave] #1675928
09/22/14 10:35 PM
09/22/14 10:35 PM
NC
NC
Its the titan brand.
Re: cooper head gasket [Re: barracuda man] #1675929
09/22/14 10:50 PM
09/22/14 10:50 PM
NC
NC
After two months of spending all my money.working my azz off on this torsion bar mopar.with all the finger cuts/bruises/soar back ect.The damm thing leaks water/what in the cat hair.Out of all the guys i race with i am the only mopar.They keep telling me to buy a chevy.
Re: cooper head gasket [Re: barracuda man] #1675930
09/22/14 11:00 PM
09/22/14 11:00 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
summit sell's a brand that is rubber coated.
not sure if these are the right size for your combo.
but I used them on a BB and worked good.
http://www.summitracing.com/parts/fog-903664060/overview/make/dodge
Re: cooper head gasket [Re: barracuda man] #1675931
09/22/14 11:00 PM
09/22/14 11:00 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
coat both sides of the gasket around all the water ports with hi-temp red silicone & let it cure for 24 hrs.
Re: cooper head gasket [Re: rickraw] #1675932
09/22/14 11:23 PM
09/22/14 11:23 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I used coopers and a copper O-ring on my 318 turbo motor. I used 'The Right Stuff' around all water and oil passages. 24lbs of boost and zero leaks.Dave
Re: cooper head gasket [Re: quickd100] #1675933
09/22/14 11:33 PM
09/22/14 11:33 PM
NC
NC
Where can i buy this 'the right stuff'
Mopars driven me to drinken.
Re: cooper head gasket [Re: barracuda man] #1675934
09/22/14 11:38 PM
09/22/14 11:38 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
It's just real aggressive silicone that takes years off your like to get it off. I've been going through the same thing and finally it turned our to be the head gaskets. They were wrong for my application. Do yourself s favor though, have the heads pressure tested. Also, get a cooling system pressure tester and find out where it's leaking.
Re: cooper head gasket [Re: camastomcat] #1675935
09/23/14 03:04 AM
09/23/14 03:04 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I used copper gaskets on my 15.19 comp. wedge, o-rings with hylamar sealer (the blue stuff) no leaks. You will have to anneal and CLEAN the gasket to reuse. I' m assuming you spelled it wrong, if not disregard what i just said.
Re: cooper head gasket [Re: cudaman1969] #1675936
09/23/14 08:26 AM
09/23/14 08:26 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Hylomar seals very well...13.5 540, o-ringed block, SCE gaskets.
no problems so far
Re: cooper head gasket [Re: jughed] #1675937
09/23/14 10:23 AM
09/23/14 10:23 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I switched to Yamabond #6 with as thin a coat you can spread with your finger.I really hated when mine leaked.
Re: cooper head gasket [Re: barracuda man] #1675938
09/23/14 10:48 AM
09/23/14 10:48 AM
an8sec70cuda Offline
I use the copper colored RTV silicone on copper head gaskets w/ O-rings. Put a light coating on the gasket, assemble, and let it sit for at least 24 hours. Never had a problem.
Done this on our 436" sb chevy w/ 14.5:1 compression.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: cooper head gasket [Re: an8sec70cuda] #1675939
09/23/14 01:17 PM
09/23/14 01:17 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Yamabond 4 worked great for me! Four years of street driving and no leaks from my copper head gaskets.
