60 ft. time still stinks!
#1675860
09/22/14 09:14 PM
09/22/14 09:14 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
my 68 dart 505 stroker ,5500 8" stall,dana 4:10 29.5 slicks. ladder bar susp. new qa1's all around. new drag torsion bars. just had professional alignment. 1.46 times. i should be in the 1.30's yes? i've went up against conv. and took it to 1800 at lights. same thing. any suggestions?
Hell Hath No Fury Like Mine
Re: 60 ft. time still stinks!
[Re: sixpacksteve]
#1675861
09/22/14 09:19 PM
09/22/14 09:19 PM
Posts: 3,415 Toronto
mshred
Toronto
At what weight? What mph and e/t?
[Re: mshred]
#1675862
09/22/14 09:21 PM
09/22/14 09:21 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
car weighs 3265 w/driver its been 10.07@133 mph
[Re: sixpacksteve]
#1675863
09/22/14 09:26 PM
09/22/14 09:26 PM
mshred
Toronto
car weighs 3265 w/driver its been [Email]10.07@133[/Email] mph
That 60' time does seem lazy...Are you sure the converter is flashing to 5500 off the line?
[Re: mshred]
#1675864
09/22/14 09:30 PM
09/22/14 09:30 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
no trans brake, foot braking it. to about 4k
[Re: sixpacksteve]
#1675866
09/22/14 09:35 PM
09/22/14 09:35 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
It could be just a matter of your weight.
I'm running roughly the same MPH with less cubes (although on Alky) but my car is lighter then yours.
I also have 4:56's and 31" tires.
[Re: sixpacksteve]
#1675867
09/22/14 09:37 PM
09/22/14 09:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Take video of your passes... mainly the starting line at a 1/4ing angle from the rear so you can see the rear of the car and the front but mainly looking at the rear tire and the body but yet see the front tire... without any info its strictly a guess... do you play on good tracks or just iffy tracks(what do the other racers say about their 60')
[Re: sixpacksteve]
#1675868
09/22/14 09:41 PM
09/22/14 09:41 PM
mshred
Toronto
But when you stab it on green, is the converter actually flashing to 5500?
Im no expert, but I am also thinking that with those tall tires you might want a little more gear than 4.10...not sure how much more though
[Re: sixpacksteve]
#1675869
09/22/14 09:57 PM
09/22/14 09:57 PM
MR_P_BODY
What RPM do you shift and what is the trap RPM.. have you measure the slippage rate on the conv... this is to verify that the tack and the the numbers are right
[Re: MR_P_BODY]
#1675870
09/22/14 10:05 PM
09/22/14 10:05 PM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
What are the cam specs, and how much compression?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: dvw]
#1675872
09/22/14 11:08 PM
09/22/14 11:08 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
My gen 3 hemi 1.45, 10.08 133
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1675873
09/22/14 11:17 PM
09/22/14 11:17 PM
B3422W5
Portage,michigan
Gear can definitely have an effect. I have seen firsthand a 112-114 Lsa cam on a motor without a lot of compression knock a good bit of 60 foot out of a car, compared to a narrower cam. Might not be the case on the OP'car..
[Re: sixpacksteve]
#1675874
09/23/14 09:18 AM
09/23/14 09:18 AM
Posts: 1,178 Indy
FlyFish
Indy
I would try foot braking it to about 2500 RPM to hit the converter harder...might be all it needs.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1675875
09/23/14 09:47 AM
09/23/14 09:47 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I had a similar problem to you, i changed from M/T to hoosiers and had to raise the tyre pressure by 3-4 psi to make it 60ft. I also went from single adj 9 way ranchos, my best 60ft with them was 1.43, to afco doubles, my best now is 1.39 but i go regular 1.40's. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mshred]
#1675876
09/23/14 10:56 AM
09/23/14 10:56 AM
Posts: 2,177 ill
dennismopar73
ill
Going up gear will lessen the converter stahl not much improvement in 60 to be found there. I thing couple things are at play here. Front end to tight , chassis set wrong in the back Converter not what it should be or could be , carb issue not big enough or tuned issues But a 500 cu motor in a 3200# car had best be a 9.70 car so something amiss here
[Re: sixpacksteve]
#1675877
09/23/14 06:38 PM
09/23/14 06:38 PM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There is a lot of info missing here. Head type, and flow? trans type? Cam duration and installed at? The slow 60 ft could be anything from tie spin to pump shooters, wrong cam, and on and on.
[Re: sixpacksteve]
#1675879
09/23/14 07:09 PM
09/23/14 07:09 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Lots of gremlins can affect staring line reaction times and 60 ft. times Which brand is the converter and was it made for your car or used when you bought it? What size squirters and cams on the carb? How much front end travel before the front tires come off the ground? some things come easy, with the right parts, and others take a lot of work to get the results you want, especially in race cars Just like women, some parts need more massaging befor they perform well Some need replacing to get the results you desire AKA, let us know the answers to the above ?
