'99 Dodge 3500 diesel w/ high idle at start up #1675777
09/22/14 06:16 PM
09/22/14 06:16 PM
North Carolina
apairof66s Offline OP
North Carolina
Just recently when we start up the diesel it high idles anywhere between 1200~1400 rpm. The temperature gauge stopped working as well.
Any ideas on where to start looking for the problem ????????
Also, this is a stock cummins
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675778
09/23/14 09:45 AM
09/23/14 09:45 AM
Guitar Jones Offline
Yeah, start with the obvious, the temp sensor.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: Guitar Jones] #1675779
09/23/14 12:23 PM
09/23/14 12:23 PM
North Carolina
North Carolina
Also just noticed the low fuel indicator light isn't working as well.
Interesting that the check engine light hasn't come on yet...........
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675780
09/23/14 05:34 PM
09/23/14 05:34 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
it won't..... we called that "1/8th tank syndrome". They used to love to fail and hang at about 1/8 tank.... when it was actually empty. Saw lots of tow ins over the years for that one. Reason I always set my trip odometer when I fill. No long term trust in that gauge.
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: J_BODY] #1675781
09/25/14 12:23 AM
09/25/14 12:23 AM
North Carolina
North Carolina
This gets more and more interesting. The "wait to start" light hasn't worked since all of this started also..............
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675782
09/25/14 12:42 PM
09/25/14 12:42 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Sounds like a ECM issue, Check for error code P0606. It will effect the WTS light and other gauge stuff too.
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675783
09/25/14 02:15 PM
09/25/14 02:15 PM
The "wait to start" light isn't going to come on unless it's cold enough, some 50 degrees or something of intake air temperature.
If the engine coolant temp sensor is bad and the PCM is seeing -40* but the intake temp sensor is saying 68* the PCM is confused and reverts to a "safe" programming mode. Have you replaced the coolant temp sensor yet?
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: Guitar Jones] #1675784
09/28/14 12:14 PM
09/28/14 12:14 PM
North Carolina
North Carolina
Thanks for the reply, The coolant temp. sensor is on the list.
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675785
10/06/14 12:57 AM
10/06/14 12:57 AM
North Carolina
North Carolina
UPDATE
Replaced the coolant temp. sensor, no change.
The temp. gauge does move from dead cold position up to 140 Degrees, but never any higher. Pretty sure it was doing that anyway prior to changing the temp. sensor....
Also at the same time replaced both batteries for different reason.
What's even more interesting is that even with new batteries and after driving around for a couple of days there's still a second or two delay from crank to firing up.
When the truck was bought months ago none of these problems existed.
Still hoping to find out what causing the high idle.
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675786
10/06/14 12:58 AM
10/06/14 12:58 AM
North Carolina
North Carolina
also the wait to start light decided to start working again.........
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675787
10/10/14 11:43 AM
10/10/14 11:43 AM
North Carolina
North Carolina
Since the temp. sending unit has been replaced, as well as both both batteries, the normal start and idle occurs after the truck has been sitting for hours, overnite etc. every time after that, once it's warmed up the idle goes back to 1200~1400. go fiqure......
Re: '99 Dodge 3500 diesel w/ high idle at start up [Re: apairof66s] #1675788
10/10/14 05:45 PM
10/10/14 05:45 PM
You need to have it scanned at the dealer with a DRBIII. The generic ones aren't as reliable and don't provide as much information as you can get off the DRB. Off hand I would be looking at the throttle position sensor and all temp sensors for any abnormal readings. Might not be the sensors themselves but the wiring. The low voltage signals can be easily manipulated by adjacent wiring.
