Re: 741, 742 & 489 center section question
[Re: DartVader69]
#167551
12/14/08 05:59 PM
12/14/08 05:59 PM
Posts: 1,730 elyria, ohio
72gtx4speed
elyria, ohio
they all take different gear set's. i believe the sure-grips will interchange. as far as rebuilding there are 2 styles, 1 is for sure and the other i've heard of them being rebuilt but don't know for sure. hope this helps, someone with more knowledge will confirm or correct me if i'm wrong.
clem
when i grow up i want to be just like sunroofgtx, god please don't let me grow up.
[Re: 72gtx4speed]
#167552
12/14/08 06:12 PM
12/14/08 06:12 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
All three sets take a different ring gear and pinion. There are 2 sure grips that were available OEM. The clutch type (rebuildable with a kit) was available OEM through the 1968 model year. The auburn (spring and cone type rebuildable only with machining) came in OEM in 1969. They are interchangable from case to case with the proper side bearings for the sure grip unit. The clutch type is by far the best.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
