no oil getting to rockers on new build? UPDATE!!! #1675269
09/21/14 06:00 PM
09/21/14 06:00 PM
Penna
70satelliteguy Offline OP
Penna
New build,Stealth heads,Mancini roller rockers. I have primed the motor(COUNTER CLOCKWISE)
turned crank to several locations and have oil pressure to my gauge but not to the rockers. Spun motor over with starter without spark plugs in and still no oil pressure to rockers but 25 psi on gauge.
Is this most likely a plug missing under the timing chain
Thanks Mike
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675270
09/21/14 06:21 PM
09/21/14 06:21 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Improperly installed camshaft bearing in the block.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: no oil getting to rockers on new build? [Re: hemi71x] #1675271
09/21/14 06:32 PM
09/21/14 06:32 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
wrong rotation position of the cam
or
upside down/backwards rocker shafts
Re: no oil getting to rockers on new build? [Re: 6bblgt] #1675272
09/21/14 06:37 PM
09/21/14 06:37 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
or
The rocker shafts is where I would look.
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675273
09/21/14 06:55 PM
09/21/14 06:55 PM
AndyF Offline
AndyF  Offline
First thing to check is to remove one of the rocker arm shafts and then slowly spin the oil pump shaft by hand using a speed wrench. If you don't get oil then the cam bearing is installed wrong. If you do get oil then you don't have a problem.
You have to have the camshaft in the correct location to feed oil to the cylinder head.
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675274
09/21/14 07:59 PM
09/21/14 07:59 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You need to find those two spots where the oil holes are in line perfectly at 4th cam journal and prime away at those two spots. You should see oil.
Re: no oil getting to rockers on new build? [Re: buildanother] #1675275
09/21/14 08:41 PM
09/21/14 08:41 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
I agree
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: no oil getting to rockers on new build? [Re: AndyF] #1675276
09/21/14 09:31 PM
09/21/14 09:31 PM
Penna
Penna
"First thing to check is to remove one of the rocker arm shafts and then slowly spin the oil pump shaft by hand using a speed wrench. If you don't get oil then the cam bearing is installed wrong. If you do get oil then you don't have a problem.
Andy I already took off one of the shafts and turned over the motor with the starter with the oil pump shaft in place and saw no oil. That should have done it don't you think???
Also,isn't there a possibility there is a plug missing under the timing chain cover somewhere? I remember reading about this in a search on the subject. Do I have to take the timing cover off to see or can I see up there with the oil pan removed?
I also had a hard time priming this motor if you remember from a previous post. It would not prime until I remover the oil filter and ran the drill with the filter off . It then primed . Do you think it could have anything to do with the oil filter?
"You need to find those two spots where the oil holes are in line perfectly at 4th cam journal and prime away at those two spots. You should see oil. "
Would it not hit those spots while turning the motor over with the starter?
Thanks Mike
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675277
09/21/14 09:41 PM
09/21/14 09:41 PM
johnmilner Offline
johnmilner  Offline
rocker arm shaft oil holes down and to the outside, small oil holes are slightly offset from the larger hold down boltholes.
Re: no oil getting to rockers on new build? [Re: johnmilner] #1675278
09/21/14 10:05 PM
09/21/14 10:05 PM
hemi71x Offline
hemi71x  Offline
You have stated that you have oil pressure on the gauge.
If you had a missing plug, it would just be dumping oil internally, and you wouldn't be getting pressure.
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675279
09/21/14 10:16 PM
09/21/14 10:16 PM
chicagoland,usa
chicagoland,usa
Better find out what's what before ya fire it. It's worth getting a 5/16 allen rod or priming tool, whatever and spin it good with a decent drill. It will put a good load on your wrist assuming all the galley plugs are in place. I've seen over 60 psi on hand held gauge with standard speed elec cord type whimpy drills.
Re: no oil getting to rockers on new build? [Re: hemi71x] #1675280
09/21/14 10:16 PM
09/21/14 10:16 PM
Been there done that on my fisrt B block build I left the plug out that is behind and under the cam gear, I did get the other three in though correctly As already stated, if you have oil pressure to the rear of the block you have all the oil galley block plugs in Please let us know what you find BTW, if the 4th cam journal has the stock size, small oil holes in the cam, it only oils the rockers for around 5 crankshaft degrees every other revoution Get someone to prime th eoil pump with one rocker shaft off and turn the crankshaft over very SLOWLY for two full crankshaft revolutions, oil should squirt out of the head quite a ways when the oil hole in the cam and blcok lines up I have heard the drill motor change tone when priming when the cam and the oil passage to the heads lined up I now have all my cams grooved on the 4 th journal to oil the rockers full time Especially those with roller lifters and stout valve springs
Re: no oil getting to rockers on new build? [Re: Cab_Burge] #1675281
09/21/14 10:53 PM
09/21/14 10:53 PM
turn dampener slit to TDC #6 compression & preoil (I forget which bank that is) then backup the crank 3/4 turn CCW till #8 is firing & preoil some more. cut a strip of newspaper 17 and 1/16" to use as a ruler on the dampener back from the TDC slit to get to #8
Re: no oil getting to rockers on new build? [Re: RapidRobert] #1675282
09/22/14 09:59 AM
09/22/14 09:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Pull the cam and rocker shafts. Stick a piece of wire through the oil passage from the head side and see if it makes it through the cam bearing from both heads.
Re: no oil getting to rockers on new build? [Re: 6PakBee] #1675283
09/22/14 10:40 AM
09/22/14 10:40 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
Shouldent he be spinning clock wise
Re: no oil getting to rockers on new build? [Re: Dons Dart] #1675284
09/22/14 10:53 AM
09/22/14 10:53 AM
NORTHERN CA
HUSTLESTUFF Offline
HUSTLESTUFF  Offline
NORTHERN CA
I was able to run a piece of welding rod down the hole in the head and by slowly turning the crank i found where the hole in the cam lined up. I had a problem between the crank and cam that was plugged and machine shop that put it together missed. He did take care of it. I did this on both sides to check the cam bearing alignment.
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL
RIP UN
Re: no oil getting to rockers on new build? [Re: HUSTLESTUFF] #1675285
09/22/14 12:42 PM
09/22/14 12:42 PM
CCW on a BB (he mentioned Stealth heads) and no need to pull the cam, when you hit the sweet spot (for each side) the rod will drop thru the cam bearing significantly & into the cam, Cant miss it/you'll feel it drop when you get there
Re: no oil getting to rockers on new build? [Re: hemi71x] #1675286
09/22/14 03:42 PM
09/22/14 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I've seen a couple of cases where the missing plug will still allow some pressure....especially with a HV pump.
Re: no oil getting to rockers on new build? [Re: 6PakBee] #1675287
09/22/14 05:19 PM
09/22/14 05:19 PM
Penna
Penna
" Pull the cam and rocker shafts. Stick a piece of wire through the oil passage from the head side and see if it makes it through the cam bearing from both heads."
Going to try this tonight!
Mike
p.s. Can someone please answer my question that if I turn the motor over with the starter should that align the holes in the cam bearing and feed oil to the heads? I have 25 lbs. of pressure on my gauge when I do this.
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675288
09/22/14 05:28 PM
09/22/14 05:28 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
What type & weight of oil are you running & standard or high volume oil pump.
With the HV pump and a good battery mine kicks right up to 50-60psi cold. If my car's been sitting for more than a month or so, I pull unplug the dist. wire and roll it over to prime it.
