1970 TA #167488
12/14/08 01:32 PM
12/14/08 01:32 PM
O
otter440 Offline OP
otter440  Offline OP
O
was wondering if the antenna is special for the TA or does it just have a longer wire Thanks
Re: 1970 TA [Re: otter440] #167489
12/14/08 02:09 PM
12/14/08 02:09 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
The mast is a standard telescopic, so really the only real difference is the long cable.
Re: 1970 TA [Re: Mastershake340] #167490
12/14/08 02:56 PM
12/14/08 02:56 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
It's the same as the 70 A-Body antenna (2926673) and it uses a separate extension cable (3501144).
