Re: weird spark ?
[Re: flyman]
#1674795
09/21/14 10:53 AM
09/21/14 10:53 AM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
This a new build or was it working/starting fine and he started having issues?
The ignition switches typically have an ign1 and ign2, one is for "run" and one is for "crank".
383, Hemi 4-Speed, AlterKtion, D60
Re: weird spark ?
[Re: flyman]
#1674800
09/21/14 12:24 PM
09/21/14 12:24 PM
RapidRobert
It was running driving good. Then it started to quit when hot but always restart when cooled off. Now no start at all.
I missed this post which tells me that the dist is turning and the reluctor gap is likely good and the wiring/ground is OK. Hard component failure: ballast (you replaced it), ECU (You replaced with a known good one) or bad coil or bad pickup. I'm gonna go out on a limb & say pickup, coil second choice EDIT With the pickup being such a pain to change I would get it good and hot to where is wont (re) start & seperate the zigzag pull apart connector & do that test ASAP while it is still real hot to confirm (or deny) that it is the pickup. Wouldn't hurt to have a helper to try the key in both positions unless you have already confirmed that everything is recieving fire in both positions & if so turn the key to ign1 "on" & you quickly under the hood pulling the coil wire and seperating the zigzag connector & drag the male end of body half across the rough surface of the intake which will make/break continuity & check coil wire for fire.
