Re: 10 pounds equal to 1 horsepower?
[Re: SleeperBee]
#1674781
09/21/14 08:37 AM
09/21/14 08:37 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The ratio of pounds to hp as equal varies a lot from a low powered car to a high powered (per pound) car. It is correct at say 300 hp to 3,000 pds car weight, but at 750 hp to 3,000 lbs, it is 1 hp per 4 pounds. Weight gets kinda important at the high end of performance, doesn't it? It takes 34 hp for an 8.80 ET 3,000 pound car to go a tenth faster. Now figure the cost of that 34 hp gain over the 880 you are already making,$$$$$$$$$$$$$$
[Re: BSB67]
#1674784
09/21/14 12:56 PM
09/21/14 12:56 PM
Posts: 1,532 off the grid
340B5
off the grid
I remember playing around w/one of those online calculators a couple years back and it came up 13hp per 10th until 10.0seconds. Then I skipped to 8.0 seconds and it took 40hp just for a tenth.
I believe I had 3000-3100lbs plugged in for the weight.
Yeah, it's got a smallblock.
[Re: SleeperBee]
#1674785
09/21/14 04:20 PM
09/21/14 04:20 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
A motorcycle racer recently mentioned this as a general rule in the mc racing community. Have you guys heard or embrace this in your racing efforts/designs? Thanks for the input. . . .
Not even close IMO Torque is torque, HP is RPM related to that torque. The Same torque at two different RPM,s will give you significant HP differences.
Heres some examples.
10# x 1100 RPM /5252 = 2.09 HP
10# x 8000 RPM /5252 = 15.2 HP
10# x 11000 RPM /5252 = 20.94 HP
If that Motorcycle races at 500 RPM, then he would be Correct.
10# x 500 RPM /5252 = .952 HP Close enough to 1 HP
