Linkage Adjustment #167475
12/14/08 12:42 PM
12/14/08 12:42 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
I've read more than a few times that if your kickdown linkage it not adjusted properly, that it can be harmful to the transmission. How so?
Grandma always said I had "hands of gold"!
Re: Linkage Adjustment [Re: CHRGR69] #167476
12/14/08 01:11 PM
12/14/08 01:11 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
improper line pressure
burns clutches
Re: Linkage Adjustment [Re: bboogieart] #167477
12/14/08 03:38 PM
12/14/08 03:38 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
burns clutches
How many positions does the lever on the transmission (727) have?
Re: Linkage Adjustment [Re: CHRGR69] #167478
12/14/08 03:59 PM
12/14/08 03:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The lever can only be positioned one way on its shaft but there is a wide variety of lever designs.
Re: Linkage Adjustment [Re: John_Kunkel] #167479
12/14/08 04:05 PM
12/14/08 04:05 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
What is the proper level for a 383/727 combo?
Re: Linkage Adjustment [Re: bboogieart] #167480
12/14/08 04:12 PM
12/14/08 04:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
burns clutches
this has to do with adjustment, not witch lever.
You will need the correct lever to fit , as well as the rest of the linkage.as said there were many designs you must have the proper set not just the proper lever.They varried by year as well as body style. Try to find some one locally that can set you up with the whole linkage from the desired engine tranny combo.
shouldn't be to hard. Look in the parts for sale section here too.
