Page 3 of 4 1 2 3 4
Re: I over torqed my tie rod end...what should I do? [Re: plazomat] #1674670
09/22/14 09:17 PM
09/22/14 09:17 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Just amazing reading this thread, How a simple problem is made to sound so difficult
Lets see they were $4 tie rods, with too short castle nuts shipped with them , so get the right nut or space with washer.
Then again the new cars just use Nyloc nuts now.
On the recall, totally different problem, defective manufacturing the allows the ball to pull out of the socket , nothing to do with a short castle nut
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674671
09/22/14 09:18 PM
09/22/14 09:18 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
GC340, Do you have a reading comprehension problem because nobody said they can't come apart. I don't know where you came up with that. What the OP and everyone else is talking about is coming apart ON INSTALLATIONN BY OVER TIGHTENING. Which can't happen and has nothing to do with what you are rambling on about.
Re: I over torqed my tie rod end...what should I do? [Re: moparts] #1674672
09/22/14 09:27 PM
09/22/14 09:27 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
You must be new here
Re: I over torqed my tie rod end...what should I do? [Re: nomore65BelvJim] #1674673
09/22/14 10:23 PM
09/22/14 10:23 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
This is more fun than Seinfield reruns.
Re: I over torqed my tie rod end...what should I do? [Re: Sxrxrnr] #1674674
09/22/14 10:36 PM
09/22/14 10:36 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
lol....wait till the middle of winter!! This is just practice!!
Re: I over torqed my tie rod end...what should I do? [Re: moparts] #1674675
09/22/14 11:17 PM
09/22/14 11:17 PM
Toronto, Ontario, Canada
plazomat Offline OP
plazomat  Offline OP
It is a $15 moog tie rod end and about $30 with shipping - not sure where you get your parts but I need the details....
I gotta get some props for starting the thread of the week-I took the nuts off the rod tonight - threads looked ok - I have a ball joint seperator coming in Wednesday to pull the joint and not damage it so I can post pictures and hopefully prove someone right...replace the rod anyway since I am there again.
Plaz-o-mat
Re: I over torqed my tie rod end...what should I do? [Re: nomore65BelvJim] #1674676
09/22/14 11:34 PM
09/22/14 11:34 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: I over torqed my tie rod end...what should I do? [Re: Sxrxrnr] #1674677
09/22/14 11:45 PM
09/22/14 11:45 PM
God's Country Maryland
GODSCOUNTRY340 Offline
I wanna play Kramer.
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674678
09/22/14 11:52 PM
09/22/14 11:52 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Careful...that could end up in place of prostock
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674679
09/23/14 12:24 AM
09/23/14 12:24 AM
Minnesota
69Y2RT Offline
69Y2RT  Offline
Minnesota
you've pulled the ball almost out of the joint
Just like you will pull the tire off the rim by over torquing the wheel studs
Its just the wrong nut, not rocket science.
Get the correct nut, don't use washers to make the wrong nut work.
Re: I over torqed my tie rod end...what should I do? [Re: 69Y2RT] #1674680
09/23/14 12:34 PM
09/23/14 12:34 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I recommended just buying a new one because they are a cheap and easy to replace part... to me it sounds like the op is worried about it and a new one is worth the peace of mind.
Re: I over torqed my tie rod end...what should I do? [Re: Silver70] #1674681
09/23/14 01:00 PM
09/23/14 01:00 PM
I know the tapered shaft goes into a tapered hole and the taper creates an interference fit. But suppose the taper on the shaft was machined 1/4" too low on the shaft. Now the tie rod housing is making contact with the center-link or ball joint arm before the tapered shaft contacts the tapered hole. As you tighten the nut it starts pulling on the ball inside the joint, possibly cracking the housing allowing the shaft to seat in place. Now the castle nut is too far down on the shaft causing the OP's problem. You guys are most likely right, it's just the wrong castle nut, but what if the above is the problem, he just puts a washer under the nut to raise it to spec, drives down the road and it comes apart? You don't take chances on critical components and a tie rod end is definitely a critical steering component.
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674682
09/23/14 01:08 PM
09/23/14 01:08 PM
dogdays Offline
dogdays  Offline
Bullpoop. If the taper is too small, the taper won't grab, either because it is too small and goes all the way through, or else because it'll pull down so far that the nut will bottom out on the stud BEFORE touching the steering arm. When either of these two things happen, one cannot torque the nut to 80 lb-ft.
It's not that easy to torque to 80 lb-ft without a really solid tapered fit. Heck, I've had to chisel off more than one nut because the taper wouldn't hold when trying to remove a rusted-on nut.
But if you want to live in fear.....
R.
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674683
09/23/14 01:14 PM
09/23/14 01:14 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Man some of these people are thick.Ill run it on my car.Im not a sky is falling guy.As for Chrysler replacing parts you better get some comprehensive reading classes.It says nothing about them being overtightened.Just like when they get dry and old.Yeah thay can and do pop out.Id pay to see you pull one thru the taper and get it to pop out of the body.Rocky
Chrysler Firepower
Re: I over torqed my tie rod end...what should I do? [Re: dogdays] #1674684
09/23/14 01:18 PM
09/23/14 01:18 PM
I didn't say the taper was too small, I said maybe too low on the shaft. If a manufacturer is unable to supply the correct castle nut can that same manufacturer be relied on to machine the taper correctly on a shaft? All it would take is 1/4" off.
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674685
09/23/14 01:24 PM
09/23/14 01:24 PM
If "if's" and "buts" were candy and nuts we'd all have a merry christmas.
Joseph Don “Dandy Don” Meredith (April 10, 1938–December 5, 2010)
Re: I over torqed my tie rod end...what should I do? [Re: GODSCOUNTRY340] #1674686
09/23/14 01:26 PM
09/23/14 01:26 PM
Minnesota
69Y2RT Offline
69Y2RT  Offline
Minnesota
If that was the case, the steering would be locked up even if it was torqued correctly the first time.
You would pull the threads out of the nut before you would damage anything else by just over tightening it.
Re: I over torqed my tie rod end...what should I do? [Re: 69Y2RT] #1674687
09/23/14 01:56 PM
09/23/14 01:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
GODSCOUNTRY340 give it up you're just digging the hole deeper. It is obvious you have every little if any experience with front end repair. Let it go.
Re: I over torqed my tie rod end...what should I do? [Re: stumpy] #1674688
09/23/14 02:02 PM
09/23/14 02:02 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I'm with 'dogdays'....get on with it!
Joe
Re: I over torqed my tie rod end...what should I do? [Re: jlatessa] #1674689
09/23/14 03:05 PM
09/23/14 03:05 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
My best guess would be just replace the da#n thing but I guess that's to easy.
Page 3 of 4 1 2 3 4
