572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results #1674542
09/20/14 06:05 PM
09/20/14 06:05 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline OP
Indy Alum Block
Indy 440-1 325CNC Heads
Indy 440-3X Intake
Quick Fuel 2.125 4500 Carb Re done by Bob Book
HVH 2” Spacer
T&D Single Shaft Rockers 1.6 / 1.6
BMBBR5 Roller Cam 283 on a 115
Jesel Belt Drive
Race Tec Pistons 15 to 1 .043/.043
Total Seal Gapless Top Ring Set
GRP Alum Rods
Callies 4.500 Crank
Custom Charlies Oil Pan
Link to Pictures
https://www.facebook.com/media/set/?set=a.684488851606801.1073741844.135175363204822&type=3
Dyno Run
https://www.facebook.com/video.php?v=707...e=3&theater
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674543
09/20/14 06:18 PM
09/20/14 06:18 PM
TTI Headers 2.125 x 3.5
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674544
09/20/14 06:20 PM
09/20/14 06:20 PM
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674545
09/20/14 06:22 PM
09/20/14 06:22 PM
Big tube headers 2.125 to 2.375 to 2.500 with a 5" collector
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674546
09/20/14 06:24 PM
09/20/14 06:24 PM
Big tube headers graph
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674547
09/20/14 07:38 PM
09/20/14 07:38 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Definitely gotta look into a set of those....
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Wv68charger] #1674548
09/20/14 08:23 PM
09/20/14 08:23 PM
What works on the dyno may not be the best for the track The motor did not reach peak on HP on either pull it looks like to me The torque graph does look a little flatter with the bigger pipes It would be a very good test at the track to find out which set makes the car go quicker and faster
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Cab_Burge] #1674549
09/20/14 08:29 PM
09/20/14 08:29 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
Very impressive, nice motor. I watched the dyno pull clip, I thought I was the only one that had exhaust pipes fall off during pulls. I use safety wire on mine now.Dave
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Cab_Burge] #1674550
09/20/14 08:46 PM
09/20/14 08:46 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
True Cab, the small headers have to stay for right now Chuck and Pete made sure I spent my money on what was absolutely needed to get the results for what we wanted to do within my budget. The only thing I know is it idled like a dream, sounded like a beast and made exactly what they said it would. Testing will have to wait till next year as the car is still in the chassis shop.
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Wv68charger] #1674551
09/20/14 09:00 PM
09/20/14 09:00 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The big tubes lost quite a bit of torque for a few horsepower gain. I would say the smaller tubes are a better choice
Keith
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Dunnuck Racing] #1674552
09/20/14 09:32 PM
09/20/14 09:32 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
That Charger is going to Rock and Roll !! Great work !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: sunroofgtx] #1674553
09/20/14 09:47 PM
09/20/14 09:47 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
we have no expectations of any ET just want to get back to racing it's hard to believe it's been 2 years but it will be worth the wait for sure!
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Dunnuck Racing] #1674554
09/20/14 10:00 PM
09/20/14 10:00 PM
Keith
I agree, with the big tires the small tubes will work good. If it was on 10.5 s I would use the big ones
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674555
09/20/14 10:15 PM
09/20/14 10:15 PM
Pa
W
Wv68charger Offline
Wv68charger  Offline
W
Pa
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Wv68charger] #1674556
09/20/14 11:10 PM
09/20/14 11:10 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That thing is gonna thump.
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Wv68charger] #1674557
09/21/14 12:13 AM
09/21/14 12:13 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Thats a nice step up!!!!!!
Russ
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674558
09/21/14 01:14 AM
09/21/14 01:14 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I know it wasn't tested here, but you have had previous experience with the Indy cross ram. Whats your guess if this motor were equipped with the Indy cross ram as far as peak torque and overall power numbers?
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Chuck@Best_Machine] #1674559
09/21/14 10:25 AM
09/21/14 10:25 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
That's a strong package, impressive. It blew the "dam" exhaust clear off in the vid. lol It's good to see you posting again. Welcome back
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: Dunnuck Racing] #1674560
09/21/14 10:48 AM
09/21/14 10:48 AM
NC
440Jim Offline
440Jim  Offline
NC
Can you give us a little more info on that cam?
LSA 115 (wider than I expected)
Intake/Exhaust at 0.050" 283?
Lift with the 1.6 ratio?
I bought your BMBB 3R from another racer for my 540 CID, 345CNC.
Keith
I liked the straight 2.125" headers. They made more torque and the horsepower pulled to the top of the pull (7400rpm). That surprised me with 572 CID. Perhaps the cam and 3X intake?
Re: 572 Wedge, 440-1 345CNC Bracket Engine. Dyno Results [Re: 440Jim] #1674561
09/21/14 12:54 PM
09/21/14 12:54 PM
ky
68roadrunner Offline
ky
Keith
3x intake and a 2" spacer, thats alot of plenum
