Sleeving a block for strength #1674472
09/20/14 01:13 PM
09/20/14 01:13 PM
USA
hudsonhornet7x Offline OP
USA
Here is a question I could use a little help with- I may be purchasing a 230 cold weather block with the thick mains that had been magnufluxed and checked out okay.
However a couple of the cylinder bores show corrosion and would need sleeved. The block has been rough bored to 4.370- Is that too thin for block strength?
What if I had all 8 sleeved? Would this make a block that was super tough both on the bottom end as well as the cylinder bores? I am not very familiar with sleeving so I thought I would ask the mopar community.
With mega block prices heading into the stupid zone would this setup be a good alternative?
Thanks Moparts!
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674473
09/20/14 01:53 PM
09/20/14 01:53 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
The 230 block is what the Super Stock guys were using when the B-1 heads first came out, they made a tick over 900 HP with them IIRC.
The original bore in those blocks was 4.340", so you should be ok if you hone to 4.375" if that would clean your worst looking bore up. Sonic check all the bores for thickness before investing a lot of time and money in it, you may be able to go farther than that if you need to.
Re: Sleeving a block for strength [Re: LSP] #1674474
09/20/14 01:57 PM
09/20/14 01:57 PM
USA
USA
I am afraid that the bores will not clean up at 4.375.
That is the drawback to this block, everything else is okay, but it will need 8 sleeves. Is this foolhardy or something that will actually help the strength?
I know that everyone will say move to an aftermarket block but the prices are just ridiculous and it ticks me off to see what people want for them.
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674475
09/20/14 02:07 PM
09/20/14 02:07 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I'd sonic that block first, I know of one B-1/230 block deal that was at 4.400" bore.
Re: Sleeving a block for strength [Re: LSP] #1674476
09/20/14 02:12 PM
09/20/14 02:12 PM
USA
USA
I will do that. If It will not go out far enough, are sleeves acceptable or will they a bad idea?
I am not worried about spending some money- in fact if sleeves will make the block stronger I would want to do that.
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674477
09/20/14 02:35 PM
09/20/14 02:35 PM
If you can't save the block by sonic testing it and boring it big enough to clean it up then think of using ductile iron sleeves Not cheap but they are way better than any of the other sleeves out there I've had several blocks sleeved with them, one was a 400 block that ended up needing 4 sleeves due to deck damage on one side and pitting in two cylinders on the other side That was the first low deck 400 stroker motor I built back in 2001, it is still running very well today after two honings and new rings, lots of runs and abuse I know a lot of NHRA stocker and SS racers that have multiple motors with eight sleeves in them, ow all of them are using the ductile iron sleeves One thing that needs to be kept in mind is the shop installing the sleeves, if your doing all eight it is not a worry, if your doing one or two then the boring and fitting of the sleeves needs to be done a certain way so they don't elongate and distort the cylinders next to the sleeves
Re: Sleeving a block for strength [Re: Cab_Burge] #1674478
09/20/14 03:05 PM
09/20/14 03:05 PM
USA
USA
I am soaking all this info in. Who makes ductile iron sleeves? I know most shops get about $ 100 per sleeve. I will research how much sleeves will cost.
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674479
09/20/14 03:12 PM
09/20/14 03:12 PM
USA
USA
How about these Ductile Iron Sleeves?
They are cheaper than I would have guessed.
http://www.powerboresleeves.com/instock.html
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674480
09/20/14 04:48 PM
09/20/14 04:48 PM
AndyF Offline
AndyF  Offline
Yes, it can be done but it is an expensive and painful process. Everything else on the block will move around when you install 8 sleeves so be prepared for a big bill from the machine shop. Everything will have to be checked and many surfaces will need to be touched up.
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674481
09/20/14 08:38 PM
09/20/14 08:38 PM
Its been a while since I had that work done I think Darton was the maker of them back then IHTHs The standard non ductile iron sleeves would pit and rust through from the water side on the drag race only motors back in the day using straight faucet water, you might get 1 to 2 years out of them back then before they would fail like that The ductile iron sleeves never rusted through on any motors I heard of after being switch to the ductile iron sleeves
Re: Sleeving a block for strength [Re: Cab_Burge] #1674482
09/20/14 10:35 PM
09/20/14 10:35 PM
USA
USA
I appreciate all the help everyone has given.
I do believe I will be buying this block, as it has been magnafluxed, sonic checked, cleaned and so on. I will be looking into some ductile iron sleeves and seeing what can be done.
I have been wanting a 230 block for quite some time and it looks like this may be the one. I have checked that it has the good main webbing so I think it will be a good one!
Thanks again Moparts!
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674483
09/21/14 10:47 AM
09/21/14 10:47 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
If this is the block from Bob Mendez you can sleep easy. He is a very fair dude. I did a post on YellowBullet about this subject about a year ago and got some real good feedback. In a nutshell;
1)Use the 'good' sleeves I think Melling offers 2 different versions and they're priced reasonable.
2)If you decide sleeve all 8, fit the sleeve O.D. to maintain maximum integrity (wall thickness) in the block foundation. If you 'go big' and bore thru the factory casting, the block will be compromised in strength.
3) Choose a shop that's had a good proven track record for this process. I'm not saying there is only one way to do this. On that 'thread' a couple shops that had success in the process had disagreed on the best method.
Re: Sleeving a block for strength [Re: HardcoreB] #1674484
09/21/14 10:49 AM
09/21/14 10:49 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Additionally in consideration of 'line 2' I would target a 4.375" finish bore with room to rebuild later.
Re: Sleeving a block for strength [Re: HardcoreB] #1674485
09/21/14 12:03 PM
09/21/14 12:03 PM
USA
USA
Yep this is Bob's block.
I have been looking for a while and just found out he is selling.
Now the big question is what do I build out of it? LOL
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674486
09/21/14 01:07 PM
09/21/14 01:07 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Although the ever vaunted and loved 230 block is always in " demand", I think the more important question is what is it you are actually trying to accomplish,and better yet,what is it you really " need" this engine to ? Sleeping 8 bores isn't for the faint of heart budget wise. You still have a stock block in the end. If your hoping sleeping makes the stock block a better block, we'll, maybe to a certain point.
I may have missed it,asI I'll admit I don't read every response.
What does this motor NEED to do ?
RIP Monte Smith
Re: Sleeving a block for strength [Re: CompWedgeEngines] #1674487
09/21/14 03:00 PM
09/21/14 03:00 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I think before i would buy a old block, sonic it buy 8 sleeves, install 8 sleeves, deck it, alignbore it, then bore and hone it i would buy a aftermarket block that could withstand some power. Unless of course i was doing a restoration in that case none of this would be needed. Just buy a aftermarket block it will be cheaper in the long run with room to grow.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Sleeving a block for strength [Re: hudsonhornet7x] #1674488
09/21/14 03:19 PM
09/21/14 03:19 PM
AndyF Offline
AndyF  Offline
I have a 230 block that I use for a welding jig. Std bore block I think, can't say I've ever bothered to spend much time looking at it.
Re: Sleeving a block for strength [Re: AndyF] #1674489
09/21/14 11:44 PM
09/21/14 11:44 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
call these guys
Snap your neck, mega G-force launch, is all I want!
Re: Sleeving a block for strength [Re: BDS871Cuda] #1674490
09/22/14 11:38 AM
09/22/14 11:38 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I'm thinking find another block.
2011 Drag Pak Challenger
