Sleeving a block for strength
#1674472
09/20/14 01:13 PM
09/20/14 01:13 PM
Posts: 1,541 USA
hudsonhornet7x
USA
Here is a question I could use a little help with- I may be purchasing a 230 cold weather block with the thick mains that had been magnufluxed and checked out okay. However a couple of the cylinder bores show corrosion and would need sleeved. The block has been rough bored to 4.370- Is that too thin for block strength? What if I had all 8 sleeved? Would this make a block that was super tough both on the bottom end as well as the cylinder bores? I am not very familiar with sleeving so I thought I would ask the mopar community. With mega block prices heading into the stupid zone would this setup be a good alternative? Thanks Moparts!
Re: Sleeving a block for strength
[Re: hudsonhornet7x]
#1674475
09/20/14 02:07 PM
09/20/14 02:07 PM
Posts: 1,313 Charlotte, NC
LSP
Charlotte, NC
I am afraid that the bores will not clean up at 4.375.
That is the drawback to this block, everything else is okay, but it will need 8 sleeves. Is this foolhardy or something that will actually help the strength?
I know that everyone will say move to an aftermarket block but the prices are just ridiculous and it ticks me off to see what people want for them.
I'd sonic that block first, I know of one B-1/230 block deal that was at 4.400" bore.
[Re: HardcoreB]
#1674485
09/21/14 12:03 PM
09/21/14 12:03 PM
Posts: 1,541 USA
hudsonhornet7x
USA
If this is the block from Bob Mendez you can sleep easy. He is a very fair dude. I did a post on YellowBullet about this subject about a year ago and got some real good feedback. In a nutshell; 1)Use the 'good' sleeves I think Melling offers 2 different versions and they're priced reasonable. 2)If you decide sleeve all 8, fit the sleeve O.D. to maintain maximum integrity (wall thickness) in the block foundation. If you 'go big' and bore thru the factory casting, the block will be compromised in strength. 3) Choose a shop that's had a good proven track record for this process. I'm not saying there is only one way to do this. On that 'thread' a couple shops that had success in the process had disagreed on the best method.
Yep this is Bob's block.
I have been looking for a while and just found out he is selling.
Now the big question is what do I build out of it? LOL
#1674486
09/21/14 01:07 PM
09/21/14 01:07 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Although the ever vaunted and loved 230 block is always in " demand", I think the more important question is what is it you are actually trying to accomplish,and better yet,what is it you really " need" this engine to ? Sleeping 8 bores isn't for the faint of heart budget wise. You still have a stock block in the end. If your hoping sleeping makes the stock block a better block, we'll, maybe to a certain point. I may have missed it,asI I'll admit I don't read every response.
What does this motor NEED to do ?
RIP Monte Smith
[Re: CompWedgeEngines]
#1674487
09/21/14 03:00 PM
09/21/14 03:00 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I think before i would buy a old block, sonic it buy 8 sleeves, install 8 sleeves, deck it, alignbore it, then bore and hone it i would buy a aftermarket block that could withstand some power. Unless of course i was doing a restoration in that case none of this would be needed. Just buy a aftermarket block it will be cheaper in the long run with room to grow.
BB, TT5,Procharged 3300lb Street Car 4.79/154
