Page 3 of 3 1 2 3
Re: Small Block Timing Chain Cover Help Needed [Re: BJS racing] #1674394
09/23/14 12:00 PM
09/23/14 12:00 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
9.56 (stock), 9.20, 9.00... the two latter had different mounting for the water pump, which was another thing that made it "interesting" for an idiot like me!
Re: Small Block Timing Chain Cover Help Needed [Re: J_BODY] #1674395
09/23/14 12:39 PM
09/23/14 12:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
9.59 (stock), 9.20, 9.00... the two latter had different mounting for the water pump, which was another thing that made it "interesting" for an idiot like me!
I never played with a 9.0 deck so I didnt know there
is 2 different water pump mounts... mine was 9.2..
and they made a R block with 9.56 deck
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674396
09/23/14 05:27 PM
09/23/14 05:27 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
fumble fingered the "9"... you are correct on the 9.56. 9.0 and 9.2 had the same front water pump mount, different from the .56.
Re: Small Block Timing Chain Cover Help Needed [Re: J_BODY] #1674397
09/23/14 06:17 PM
09/23/14 06:17 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
Ok thanks guys! I thought that was the way it was but wanted to make sure. Sometimes the brain will only retain info for so long before it has to be beaten back in there!
Back in the swing of things at Painless again! Great to be back!
Page 3 of 3 1 2 3
