Page 1 of 3 1 2 3
Small Block Timing Chain Cover Help Needed #1674354
09/20/14 01:56 AM
09/20/14 01:56 AM
HR3128 Offline OP
HR3128  Offline OP
What front cover fits an R3 block? I have seen listings for regular small block covers & R3 block covers. Then covers for R3 block with standard water pumps & R3 blocks with Race water pumps. Anybody know what's the difference in these covers? I'm thinking of using this pump(Moroso 63565) . What cover will it fit? Thanks for your help.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674355
09/20/14 02:26 AM
09/20/14 02:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The difference is tall block or short block covers
so which deck height do you have... I'm sure the
pump fits either cover.. the holes for the short deck
look like a half moon in the cover
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674356
09/20/14 02:52 AM
09/20/14 02:52 AM
HR3128 Offline OP
HR3128  Offline OP
It's a 9.00 deck.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674357
09/20/14 03:42 AM
09/20/14 03:42 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.ebay.com/itm/Mopar-Performanc...2a1&vxp=mtr
...this is like the one you need. And I can almost guarantee that Jegs doesn't have it, or able to get one.
Re: Small Block Timing Chain Cover Help Needed [Re: J_BODY] #1674358
09/20/14 03:45 AM
09/20/14 03:45 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674359
09/20/14 03:49 AM
09/20/14 03:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It's a 9.00 deck.
Ok... the cover will have the 1/2 moon openings in
the 2 ports going into the block... MP part is P4876631
this is for the 9" and 9.20 deck with the standard
pump and P4876632 for the same deck and front motor
plate.... I use the 631 with a Meziere water pump with
a motor plate and never have any issues(my pump has
just the 2 ports that bolt on to the plate/block..
if your pump has the blades beyond the flat of the
mount area you need the 631 cover
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674360
09/20/14 11:43 AM
09/20/14 11:43 AM
HR3128 Offline OP
HR3128  Offline OP
So MP part is P4876631 is the one to get. Is this one of the MP items that is on permanent back-order?
What is the difference between this one & a standard 340 type cover?
Thanks for the info.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674361
09/20/14 03:25 PM
09/20/14 03:25 PM
Out West
408strokerdart Offline
Out West
On the short deck block (like the one you have) the upper bolt hole above the water port is much lower than stock and the water port is "D" shaped to maintain some thickness for sealing the passage.
There are a few of ways to solve the problem of adapting a standard water pump to your block. First is like Mr P said, find the special timing cover to fit. I have found these pretty hard to find now, but you might be able to come across a used one. Option two is belt drive cam like Jbody said and a pair of adapters to mount a Meziere pump. Third way is the previously mentioned belt drive and then a remote mounted pump pushing water into the center core plugs of the block.
Re: Small Block Timing Chain Cover Help Needed [Re: 408strokerdart] #1674362
09/20/14 04:44 PM
09/20/14 04:44 PM
AndyF Online content
AndyF  Online Content
I could build a short deck height version of my two piece timing chain cover. It would be expensive to make in low qty, but not too much more than the MP sand cast unit.
Re: Small Block Timing Chain Cover Help Needed [Re: AndyF] #1674363
09/21/14 12:34 AM
09/21/14 12:34 AM
HR3128 Offline OP
HR3128  Offline OP
Thanks for the info. This is the first time I've messed around with small block stuff. I never imagined there were so many variables.
Just to make sure I understand, an R3 9.00 block & an R3 9.20 block have the same water pump port & lower pump bolt hole location with a different port shape. The upper pump bolt hole locations are different for the 9.0 & the 9.2. Correct?
If this is correct, I also need a new motor plate to make this motor fit the car.
Re: Small Block Timing Chain Cover Help Needed [Re: AndyF] #1674364
09/21/14 01:08 AM
09/21/14 01:08 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
That's a great looking cover Andy.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small Block Timing Chain Cover Help Needed [Re: AndyF] #1674365
09/21/14 01:37 AM
09/21/14 01:37 AM
HR3128 Offline OP
HR3128  Offline OP
All the parts on your site look great. Do you make any motorplates or water manifolds for the R3 blocks bolt pattern?
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674366
09/21/14 01:50 AM
09/21/14 01:50 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
That is a work of art Andy......I like the two piece bit too.
I think Ritter - Weber has a short deck motor plate available , but will punch one out in any configuration you desire if it isn't in stock.....beauty of the turret press.
Start adding up a sand cast cover and a quality timing set.........you are very close to the open belt cam drive.
Depending on your end use , there are additional benefits to this set up too.
I went open belt and remote water pump on my deal......mostly for the show and tell factor.
Last night was the first public appearance and it definitely turned heads.
After a couple days driving , it is ready for some serious business.
If I am lucky , I'll get a couple races in before it is time to put it up for the winter.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674367
09/21/14 02:33 AM
09/21/14 02:33 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I bought this:
to cut to make spacers for this:
which wasn't "pretty".... and 408strokerdart had some demand and fabbed up these beauties:
...and this bitchin motor plate:
..... I'm so far over my head in this project it aint funny! It's been a learning experience and I have to thank Tubtar, W5dart66, OU812 and 408strokerdart for guiding me through this mess.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674368
09/21/14 03:35 PM
09/21/14 03:35 PM
No, I don't make any short deck stuff at the moment but I have the CAD files on hand. The market for that stuff is so tiny it just isn't worth spending the time to design the parts. I'd never get paid back for my time. I suppose if someone local had a short deck height motor program I'd work with them to make the parts. It doesn't seem like it would be too difficult to take some of my existing designs and modify them.
I add a couple of threaded holes to the timing covers so the motor plate can support the engine even with the water pump removed. That allows racers to pull the camshaft while the engine is still hanging from the plate. With the two piece cover you don't have to disturb the oil pan seal either so that saves a bunch of time and leaks.
Re: Small Block Timing Chain Cover Help Needed [Re: AndyF] #1674369
09/21/14 03:47 PM
09/21/14 03:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like the idea of a couple extra bolts to hold the
engine up with the front off ... I wish I
had a 2 piece cover to get at my gear drive if I wanted
to cam the cam or the cam timing.. but being I have
the sand cast version I have to pull the cover and
the motor plate to get at mine.. which means a floor
jack under the pan and a block of wood
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674370
09/21/14 03:56 PM
09/21/14 03:56 PM
Been there done that! That is why I designed the two piece cover to clear the Milodon gear drive. Not sure if other brands of gear drive will clear also but the Milodon fits okay.
Re: Small Block Timing Chain Cover Help Needed [Re: AndyF] #1674371
09/21/14 04:36 PM
09/21/14 04:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I would have paid for those "not worth your time" parts.... Thankfully Brian Smith came through for me. I'm not a machinist, or much of a fabricator.... I bought two pieces of aluminum while I was in Phoenix, got a pattern to get some ideas off from another member. What I still would have needed to do was to take a day off work and travel 50 miles to Lake Havasu to discuss having my plates cuts to the design I needed.... Either way it would have been a very expensive motor plate by the time all was done.
Re: Small Block Timing Chain Cover Help Needed [Re: MR_P_BODY] #1674372
09/22/14 12:56 AM
09/22/14 12:56 AM
HR3128 Offline OP
HR3128  Offline OP
Mr. P Body - Do you have a part number for the Meziere pump you use?
I looked at their site & did not see anything listed for the short deck R3 bolt pattern.
I did find a couple P4876632 covers for sale, about $400. That looks to be the easiest way to go.
Re: Small Block Timing Chain Cover Help Needed [Re: HR3128] #1674373
09/22/14 01:08 AM
09/22/14 01:08 AM
Out West
Out West
You use a standard SB mopar pump with those covers. They accept the standard water pump bolt pattern for the two bolts on each side of the port.
Page 1 of 3 1 2 3
