M/T ET Street Radials, when should I replace them? #1674324
09/20/14 01:20 AM
09/20/14 01:20 AM
Ohio
moparjoe360.4 Offline OP
Ohio
I'm getting down on tread on my Et Streets, they're down to the wear bars. I've seen guys running the completely bald. So my question is when should I replace them?I'm hoping can get one more season out of them then I'll be happy.
Re: M/T ET Street Radials, when should I replace them? [Re: moparjoe360.4] #1674325
09/20/14 01:35 AM
09/20/14 01:35 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Replace them when your 60 ft falls off. That's if you are talking strictly racing. If you are talking legality for the street the when you hit the wear bars it's done.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: M/T ET Street Radials, when should I replace them? [Re: 1967dartgt] #1674326
09/20/14 01:45 AM
09/20/14 01:45 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
I've personally been 8.30's with cords showing.....run them to the cords ....your experiences may vary
....BAD A$$ STREET CAR.....
Re: M/T ET Street Radials, when should I replace them? [Re: 1967dartgt] #1674327
09/20/14 01:56 AM
09/20/14 01:56 AM
Ohio
Ohio
Thanks that's what I figured. I've already pretty much decided that I should only use them at the track or very limited local street use just wasn't sure when to consider them completely junk.
Re: M/T ET Street Radials, when should I replace them? [Re: n20mstr] #1674328
09/20/14 03:19 PM
09/20/14 03:19 PM
Ohio
Ohio
I think I'll replace them before the cords are showing. But 8.30s is inpressive on worn out drag radials.
Re: M/T ET Street Radials, when should I replace them? [Re: moparjoe360.4] #1674329
09/20/14 03:47 PM
09/20/14 03:47 PM
Renton Washington
Triple Threat Offline
Renton Washington
Til there ain't no more rubber.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: M/T ET Street Radials, when should I replace them? [Re: Triple Threat] #1674330
09/20/14 04:59 PM
09/20/14 04:59 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
and when the cords first start to show.. it wears super duper fast...
Re: M/T ET Street Radials, when should I replace them? [Re: Triple Threat] #1674331
09/20/14 08:30 PM
09/20/14 08:30 PM
I've never seen cord on any of the sets I've used I have had several sets that had a lot less of the side grooves left than yours and no cords showing when removed
Re: M/T ET Street Radials, when should I replace them? [Re: Cab_Burge] #1674332
09/20/14 08:57 PM
09/20/14 08:57 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
My 325's have been raced/street driven since 2005. Still able to pop the tire up !!
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: M/T ET Street Radials, when should I replace them? [Re: 1967dartgt] #1674333
09/20/14 10:32 PM
09/20/14 10:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is correct.. being you are running the ET streets
I assume you run the streets... if a cop sees cords
hanging out he CAN give you a ticket.. and most likely
will.. and thats not talking about rain on the roads
Re: M/T ET Street Radials, when should I replace them? [Re: MR_P_BODY] #1674334
09/22/14 12:30 AM
09/22/14 12:30 AM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Agreed. I had mine for about 3 years, they worked exceptionally well... however, when I got to the wear bars, my 60' times went south. I have a 2nd set of rims with T/A radials for street now and bought a set of M/T slicks which I rarely use on the street that are on the 15x10 rims. I noticed small bits/chunks of rubber missing exposing the cords on the drag radials from driving on the street... uhhhh, no thanks. Whatever you do, just be safe.
Re: M/T ET Street Radials, when should I replace them? [Re: Triple Threat] #1674335
09/23/14 10:45 AM
09/23/14 10:45 AM
an8sec70cuda Offline
Don't replace them until you see the cords showing.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: M/T ET Street Radials, when should I replace them? [Re: an8sec70cuda] #1674336
09/24/14 12:46 AM
09/24/14 12:46 AM
Az
Crizila Offline
Crizila  Offline
Az
Major bad idea IMO. It's why tires have wear bars or depth holes. I'm sure M/T ( if he was still alive ) would shat a brick on that one. You guys that run them to the cords are - pretty brave.
Fastest 300
Re: M/T ET Street Radials, when should I replace them? [Re: Crizila] #1674337
09/24/14 12:55 AM
09/24/14 12:55 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
There was only a single afternoon between the wear bars starting to touch and the cords showing thru on mine….. and a half a tank of gas.
Re: M/T ET Street Radials, when should I replace them? [Re: Crizila] #1674338
09/24/14 10:02 AM
09/24/14 10:02 AM
It sounds crazy, but every racer I know on radials does the same thing. From my experience, once the center "tread" (the two grooves) is gone, the tire is only a little over half used up. Mine will still 60 foot consistently right up until I replace them.
CHIP
Re: M/T ET Street Radials, when should I replace them? [Re: an8sec70cuda] #1674339
09/24/14 11:06 PM
09/24/14 11:06 PM
Ohio
Ohio
This is exactly the feed back I was hoping to get. I hardly ever use them on the street because the first road trip I ever took on them we hit rain and I got 2 ft sideways at 60-65 MPH on the e-way. After that I got another pair of rims n I run 31/10.5/15 son the street now plus they help a little with gearing as I'm sure you all know 4.10s aren't the greatest highway gears. Thanks for everyone's input!
Re: M/T ET Street Radials, when should I replace them? [Re: moparjoe360.4] #1674340
09/24/14 11:47 PM
09/24/14 11:47 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
I just replaced mine, they were 7 years old. They were dry rotted/cracked in the treads. Still had plenty of tread left but I didn't feel comfortable racing them like that.
For what its worth, M/T site suggests replacement after 4 years.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: M/T ET Street Radials, when should I replace them? [Re: an8sec70cuda] #1674341
09/25/14 09:40 PM
09/25/14 09:40 PM
Az
Crizila Offline
Crizila  Offline
Az
Would you run your daily driver over 100 mph with the cords showing on the tires??
Fastest 300
